pigsy
Re: very cheap case
Mon Mar 19, 2012 5:09 pm
Here on ebay, £2.40 for 5  ,should be easy to cut holes with a craft knife or a dremel  http://www.ebay.co.uk/itm/BUSI.....500wt_1054
Shpaget
Re: very cheap case
Mon Mar 19, 2012 7:53 pm
http://www.rapidsupplies.co.uk.....es-7-p.asp
It's cheaper.
SlobJunkie
Re: very cheap case
Mon Mar 19, 2012 8:27 pm
I don't think it would be good idea using this type of case for our Raspberry PI's with the case being made of polypropylene
The problem is with the two parts of the case rubbing against each other when opened and closed the box will generate a lot of static, wouldn't want to subject my PI to static.  I think I would rather use a potting box instead which are cheap as chips
like this  http://goo.gl/99Ohx
pigsy
Re: very cheap case
Mon Mar 19, 2012 10:14 pm
hmm hadnt thought of that
RaTTuS
Re: very cheap case
Tue Mar 20, 2012 8:58 am
paper bag?
Covfefe
trikidiki
Re: very cheap case
Tue Mar 20, 2012 6:38 pm
RaTTuS said:
paper bag?
Nasty paper cuts!
TheCrazyInventor
Re: very cheap case
Tue Mar 20, 2012 7:11 pm
SlobJunkie said:
I don"t think it would be good idea using this type of case for our Raspberry PI"s with the case being made of polypropylene
The problem is with the two parts of the case rubbing against each other when opened and closed the box will generate a lot of static, wouldn"t want to subject my PI to static.  I think I would rather use a potting box instead which are cheap as chips
"Static"...?
Meh, don't worry too much about ESD. The Pi will be fine inside that box. And besides, other plastic surfaces also build up a substantial charge when two surfaces are separated from each other.
"Anything that can possibly go wrong, does" -M
Stewrat
Re: very cheap case
Tue Mar 20, 2012 7:54 pm
It's cheaper.
How is £4.35 for 1 including delivery cheaper than £2.40 for 5 inc delivery?
