Re: Mac VMWare Fusion & Rapberry Pi
Posted: Fri Mar 09, 2012 11:33 pm
by oranda
Is it possible to run a emulated Raspberry Pi within VMWare Fusion on a iMac?
If so, how?
If not, how else could it be done?
Posted: Fri Mar 09, 2012 11:39 pm
by oninoshiko
VMWare does not (AFAIK) emulate an ARM. You will have to do one of two things:
run a linux distro with qemu-arm on vmware (I think someone has a setup already configured for vmware, does fusion use VMWare workstation images?)
get a copy of qemu-arm for MacOS
Posted: Sat Mar 10, 2012 7:23 am
by nick.mccloud
Yes it is, I've done it.
See http://www.raspberrypi.org/forum/projec ... oremulator
Posted: Sat Mar 10, 2012 8:27 am
by AlArenal
It's easier, though, todirectly run qemu on the Mac.
1. Download / install Apple's Xcode. It's freely available in the Mac App Store. If your system is too old and not supported by App Store, download the appropriate Xcode version for your Mac OS X on http://connect.apple.com/ . Registration there is free, you only need your Apple ID.
2. Install the appropriate version of Mac Ports from http://www.macports.org/install.php on your Mac.
3. Open a terminal and type
sudo port install qemu +target_arm
It's gonna install qemu with the arm emulator.
4. You can now use the qemu based packages floating around here in the forums
Posted: Mon Sep 23, 2019 7:54 pm
by emceeMC
That link is dead :(
Posted: Tue Sep 24, 2019 9:21 am
by jamesh
Not surprising, it's 7 years old!! I think you might win the oldest necro award with this one. I'd suggest Google for more information on this one.
