beylow
Problem with RC servo connect to pi
Sat Mar 16, 2013 7:40 am
Hi there,
I've got some problem with RC servo.
I'm using a servo which I bought from Sparkfun. https://www.sparkfun.com/products/9064
Since it requires 5V voltage and lots of currents, I have to use a external power for servo.
I've followed the instruction on http://learn.adafruit.com/adafruits-ras ... r/overview.
I used a 5V phone charger instead of battery.
When I connect the signal cord to raspberry pi, servo kept running until it reached the maximum angle, even before I issued the python code to control servo. Now, I cannot figure out why it is like this.
Does anyone have an idea?
Thanks a lot.
BTW. I've tried this under both the latest Wheezy and Occidentalis firmware, same result.
beylow
Re: Problem with RC servo connect to pi
Fri Mar 29, 2013 9:01 am
Up. Up.
joan
Fri Mar 29, 2013 9:31 am
Possibly noise from the floating control signal. Does it operate properly once your program starts?
beylow
Fri Mar 29, 2013 9:21 pm
joan wrote:Possibly noise from the floating control signal. Does it operate properly once your program starts?
It doesn't.
I have even tried it with another pi, same problem.
alexeames
Fri Mar 29, 2013 9:44 pm
Have you connected the GND on your power supply to Pi GND?
Which pin are you attaching it to?
Have you seen the photos and layout of how I did it?
Do they match with yours?
http://raspi.tv/2013/how-to-make-your-o ... aving-demo
Alex Eames RasPi.TV, RasP.iO
beylow
Sat Mar 30, 2013 10:44 am
alexeames wrote:Have you connected the GND on your power supply to Pi GND?
Hey alexeames.
It actually works with your configuration!
Thanks a lot!
I was trying to use the servo to open my door. But sadly, the servo torque isn't powerful enough. I have to consider buying another servo.
alexeames
Sat Mar 30, 2013 11:41 am
Way to go. Excellent. Yes you'd need a pretty large and powerful servo to handle a door.
