alysko
how to suspend/restart ?
Thu Mar 14, 2013 10:36 am
I would like to replace expensive thin clients by raspi. I test it with rpitc distro which works fine with RDP.
But it's not conceivable to provide a system that can not be turned off (or suspend) and restart without having to plug / unplug : end users have extremely limited knowledge of computers.
Is it possible to turn on and off (or similar : goal is 1/ to restart if a bug occurs 2/ to "stop" the machine to reduce power consumption) with a key combination, for example? Or another solution?
Thanks.
ghans
Re: how to suspend/restart ?
Thu Mar 14, 2013 11:23 am
Thu Mar 14, 2013 1:32 pm
To save 90%+ of power - turn off screen and leave RPi on :)
Example: One of my screens (old 15" LCD) uses 39W when active. The Pi uses 3W. So the screen takes 93% of the total power.
alysko
Fri Mar 15, 2013 12:38 pm
Thanks.
Ok, this is not primarily to save energy. Above all, it's to make a reset in case of bug.
And I didn't say, but I don't want to increase the cost of the set (I already have to buy the case).
So, first solution : beuurrrkkk, don't want to corrupt SDcard and system. People
Third solution : too expensive
Second solution : EXCELLENT ! No for all kind of situation, I did not know there was a watchdog.
It is curious that there is no box with a button connected to GPIO.
Just found this reset button project : http://rpi.tnet.com/project/hardware/resetbutton
oohhh ! Another great surprise ! model B rev 2 have a reset :) http://raspi.tv/2012/making-a-reset-swi ... spberry-pi
I just have to find "2-pins" and reset switch :)
