Dinosaur
Re: VirtualBox and SD card
Fri Feb 24, 2012 10:51 am
I have put the debian system downloaded from here onto a SD card.
Then used the 'VBoxManage internalcommands createrawvmdk -filename path\to\usb.vmdk -rawdisk \\.\PhysicalDrive1' command to create a vndk file pointing to the SD card.
When I try to use this in VirtualBox at the add hard disk option under IDE controller in storage settings I get this error
Failed to open the hard disk F:\Rasp Pi\VirtualBox\mystuff\usb.vmdk
The medium 'F:\Rasp Pi\VirtualBox\mystuff\usb.vmdk' can't be used as the requested device type.
Am I doing something wrong or is it not possible to use the SD card in this way?
nick.mccloud
Fri Feb 24, 2012 11:24 am
No, you can't do it this way.
The first partition on the card is FAT but with ARM code, not X86 code.
There are a variety of postings on here about running the Debian6 image but you will have to run it through an emulator that allows you to run ARM code.
See Simulator & emulator downloads for download of a VirtualBox image that is setup to run an emulator - you will benefit from reading the linked posts for VirtualBox & the Official image and the whole of all three threads.
Dinosaur
Fri Feb 24, 2012 3:21 pm
Thanks.
I have read those threads and found them fairly inpenetrable.
So I will wait for a true idiot guide or the real hardware.
nick.mccloud
Fri Feb 24, 2012 3:39 pm
Step by step should work.
First, click here to download the VirtualBox image. Let me know when that's done.
