amiga65
Re: Small touchscreens
Sun Jul 31, 2011 11:34 pm
Does Anyone know of a source for cheap touchscreens that can be used with this?
I was looking for a screen in the 3" 5" range for another project but gave up on it due to costs of small touchscreens. This thing is just begging for one. I for-see a home built handheld media player / computer in My future. :)
Novo
Mon Aug 01, 2011 6:01 am
Cheapest Touchscreen I found was 80$. (7")
I got a small 2,4" Keychain Display for 3€ and can use it with lcd4linux to display status :)
Cafe
Mon Aug 01, 2011 8:13 am
Quote from Novo on August 1, 2011, 07:01
Cool. Do you have links?
(Including links will be help other readers leverage your sources/knowledge, not to mention saving a lot of time. :) )
ShiftPlusOne
Mon Aug 01, 2011 9:58 am
Look up a company called Lilliput.
Acaloth
Mon Aug 01, 2011 2:49 pm
Would also wish to know where to get a small monitor...i think about 8-10"
because i would like to use this thing instead of a laptop.
Astralix
Tue Aug 02, 2011 3:30 pm
If the video chipset supports low frame rates and some degrees of freedom for the timings you might patch a driver to send RGB and you can connect a car lcd panel. Still expensive though.
If the mentioned 1.27mm header routes some lines like I2C and/or serial USART you can adopt a side-panel display. But this is more for lcd4linux than a real desktop solution.
truxntrax
Wed Aug 03, 2011 6:53 pm
Small keychain tutorial for dockstar:
http://forum.doozan.com/read.p.....35,quote=1
Des_Zac
Thu Aug 04, 2011 7:43 pm
You could get a 7" Proximus touch screen and use a usb strip (IDK what they are called, the thing where you plug it into a USB port and it has 4 or so ports on it?) and plug it in to that I think.
anicho
Fri Jan 25, 2013 4:38 am
Has anybody got the Pi working with a proximus touchscreen, if so could you help a brother out :)
