hvc123
Re: Where are you going to put your Raspberry Pi?
Thu Feb 02, 2012 4:35 pm
im going to put mine back in my dreams where they are at the moment
Hans Free
Thu Feb 02, 2012 7:12 pm
I have two use scenarios.  One is tucked behind the TV, connected to a spare HDMI port.  The other is as a portable device for use elsewhere in the house.   This latter one is probably just as a prototype because once you add sufficient batteries it will probably be too bulky to actually wear on your belt - in which case, why not just use a smart-phone?
I am not worried about keyboards or portable displays, as I am aiming for pure voice control and output most of the time.  Kind of like Siri, but more useful around the house.  While Siri can tell you where the closest French restaurant is, it can't tell you where you left your pinking shears.
I have experience doing voice input and output for people with reading/typing disabilities.
tufty
Thu Feb 02, 2012 7:27 pm
James - as the edges aren"t rounded off, you may have found an alternative to the banhammer (and a use for the inevitable boards that fail testing)
toxibunny
Thu Feb 02, 2012 8:27 pm
Mine's getting glued into a scooped-out PSone case and put on top of my main PC. It's going to be displayed in a window on said main PC using the RCA video-in on my old analogue TV tuner card, and it's going to be used purely for learning programming - I'll get a simple ''notepad' with colour-coding' 'dev environment' set up, along with the necessary libraries installed, and that's it. any 'googling for docs/tutorials' is going to be done on the now oft-mentioned PC, and stuff like .wav files and picture files are going to be transferred over using a USB stick - the raspi's going to be lean, clean, and coding-only.
Hi tufty!
note: I may or may not know what I'm talking about...
PhilFrisbie
Thu Feb 02, 2012 9:37 pm
I will mount mine to the back on a monitor with velcro.
I will use it to optimize C code for ARM platforms.
psergiu
Thu Feb 02, 2012 10:20 pm
JamesH said:
a) Up my bottom
b) Using it as an alien probing device.
As long as you don't post pictures of your setup, we're fine
A) Until i am able to buy more - on my desk. After that, in the case of a burned-out Miglia TVMax TV-tuner - will stack perfectly with my mac mini.
B) World Domination !
riffraff
Thu Feb 02, 2012 10:35 pm
I have an old Magnavox DVD player that should hold all of the gear.
TPA5
Thu Feb 02, 2012 11:52 pm
a) Inside of an arcade cabinet
b) Using it as a MAME emulator for an inexpensive, slim cabinet build
Docteh
Fri Feb 03, 2012 1:24 am
I have a bunch of penguin mint tins on my desk, might fit in one. If not there is always wood
Mr_Sheesh
Sun Feb 05, 2012 7:19 pm
A: I'm still thinking on that, worst case I'll fake a case with cardboard, and 2-sided tape it up on the main rolling computer stand I use. Looking for a 3D printer in the Seattle area that I can borrow somewhat
B:Mainly a C/C++ Linux development station, the RPi will make a NICE embedded development platform, as well as wearable computer I'd think, I've thought of a number of uses, and I'm trying to think of anything to help people out. Once the huge production runs start popping out anyways.
FollowingGhosts
Sun Feb 05, 2012 9:20 pm
Just remembered I have an old dead SNES in a cupboard somewhere, a Pi would be perfect tucked away sat on top of a modern console like an Xbox.
If not, it'll be a cardboard box or something similar with ethernet and power going in, probably next to my network switch. The problem I'm finding now is, once I have one Pi, I'll want many more. This could end expensively..
Jaseman
Mon Feb 06, 2012 9:12 am
Under a bus, wired up to some C4.
Thats a joke by the way - don't get any ideas!
ukscone
Mon Feb 06, 2012 2:29 pm
when you get rended to some secret base somewhere can I have your Raspberry Pi?
walney
Mon Feb 06, 2012 3:47 pm
That's buggered you chances of ever going to the US...
gorpo
Mon Feb 06, 2012 6:32 pm
1. Test it as a media centre for family/friends
2. Connect it to speakers and use it as a music streaming device throughout the house
R2_Coder
Mon Feb 06, 2012 8:59 pm
I am planning on rebuilding my Interactive R2-D2 to run off this board.  But first it will sit on my desk till I can get VNC setup and order some more parts for it.
evil twin
Tue Feb 07, 2012 5:45 pm
The first one will most likely end up inside my PC's 5,25" bay, with a USB hub and an Ethernet switch, as an 'embedded LAMP server' for development and some Linux remote management education. I plan to access it via telnet or SSH, possibly remote desktop. No need for an extra keyboard and screen.
