jraff1
Re: HDMI to VGA adapter
Sun Jan 29, 2012 9:23 pm
A friend found this cute converter HDMI to VGA - http://www.meritline.com/hdmi-.....77485.aspx
This is not cheap but less expensive than a HD screen.
SE43
Sun Jan 29, 2012 9:29 pm
Good find, converts to about £26, will come in use for many people!
EDIT: Just found a UK website for about same price http://www.sourcingmap.com/inp.....=ukfroogle
Montekuri
Sun Jan 29, 2012 9:37 pm
A "RCA to VGA" converter is $10 cheaper:
http://www.meritline.com/tv-vi.....42213.aspx
Themroc
Sun Jan 29, 2012 9:44 pm
... and will look $20 uglier. Better try this + an HDMI to miniHDMI adapter.
abishur
Mon Jan 30, 2012 4:44 am
I tend to be distrustful of such (relatively) inexpensive hdmi to VGA adapters.  My suspicion is that the ASUS laptop this works with sends an analog signal out along with the digital.  It then does a passive conversion to VGA and most the cost comes from it being a special pin out.  This, of course, is just my cynical view and maybe it is an active convertor.  I'd have to see some strong confirmation on the subject before paying 30  bucks for it
Dear forum: Play nice ;-)
Themroc
Mon Jan 30, 2012 9:57 am
Me thinks these converters are way overpriced. Nowadays, they can make a complete linux box for just $25 , so why should such stupid crap cost a fortune? It's not exactly rocket science to glue a TFP9431 on a little PCB. This is what a digital/serial to vga converter should cost... Anyway, dunno if you consider it "strong" but here is some kind of confirmation. And a update for the "even better" link:
http://www.ebay.com/itm/New-HD.....20bdee36bf
scarfy
Mon Jan 30, 2012 11:33 am
bredman
Mon Jan 30, 2012 11:40 am
The unit that Scarfy found is very interesting. It uses a 5v power supply, so (in theory) it could share a power supply with the RPi, if you are willing to chop and join some power cables.
drgeoff
Mon Jan 30, 2012 12:01 pm
While it is likely that the supplied adaptor will have a higher current output capability than the converter requires, it may not be enough to handle the extra demand from the RP.  Not saying it won't, but generally higher power means a more expensive unit and there isn't any incentive for the manufacturer to supply a more expensive PSU than necessary.
Skygod
Tue Jan 31, 2012 9:20 am
Thanks for the link Scarfy. Looks a promising candidate to avoid paying $200 for an HDMI TV or binning my existing LCD and getting one with DVI input and using a HDMI/DVI dongle.
RaTTuS
Contact: Twitter YouTube
Tue Jan 31, 2012 10:01 am
http://www.amazon.co.uk/Konig-.....omputers_2 for the UK people - £54 - I'm not sure how good etc ...
6+6 = 66?
Covfefe
drgeoff
Tue Jan 31, 2012 12:25 pm
RaTTuS said:
http://www.amazon.co.uk/Konig-.....omputers_2 for the UK people – £54 – I'm not sure how good etc …
6+6 = 66?
Doesn't seem to offer any more than the one that SE43 linked to in post #2.  £26 with free shipping from China.  Only 2 left!
Or have a look at item #280621510093 on ebay.co.uk and wonder why 258 people have each forked out £935 for one.  (And another £3 delivery – the cheek!)
Perhaps, because when you look at the list of sales they were at £35, which is semi-reasonable.
Themroc
Tue Jan 31, 2012 2:03 pm
drgeoff said:
Doesn"t seem to offer any more than the one that SE43 linked to in post #2.  £26 with free shipping from China.  Only 2 left!
Yes it does! The konigs claim to support HDCP 1.2 (which of course makes a lot of sense, especially on the VGA output ) and to use 10 bit DACs – on a CRT you might see the difference. But since LCD monitors usually have 8 bit ADCs inside i guess it doesn't matter much… And no worry at all, them chinamen have enaugh of this stuff:
http://product.madeinchina.com.....0762.shtml
http://www.dealextreme.com/p/h.....rter-71816
Edit: even cheaper:
http://www.ebay.com/itm/New-Di.....19cc5ea561
grumpyoldgit
Tue Jan 31, 2012 2:09 pm
drgeoff said:
RaTTuS said:
http://www.amazon.co.uk/Konig-.....omputers_2 for the UK people – £54 – I"m not sure how good etc …
6+6 = 66?
I gather that when a supplier temporarily runs out of stock but intends to keep selling the item, it is often easier to increase the price to a ridiculously high amount, rather than pull the advert and have to pay to insert it again.
arm2
Tue Jan 31, 2012 5:16 pm
The £35/£835 one on ebay http://www.ebay.co.uk/itm/280621510093
says "Does not work with Sky box". Any Idea why?
Might the RPi have them same problem?
grumpyoldgit
Tue Jan 31, 2012 5:53 pm
Not sure why you would want to attach a Sky box to an old PC monitor. My recollection is that the recent boxes have HDMI, SCART and the old RF so there would be no need for a converter for even the oldest TVs.
drgeoff
Tue Jan 31, 2012 5:59 pm
Says it works up to UXGA - which is 1600 by 1200.  SkyBox is 1920 by 1080?  I don't have a SkyBox with HDMI so don't know.
arm2
Tue Jan 31, 2012 9:26 pm
Well spotted I should have looked closer. 1920x1080 is only 8% more pixels than 1600x1200 but it could be the straw that broke the camels back!
Burngate
Wed Feb 01, 2012 12:01 pm
Also says it does 1080i @ 60Hz
Maybe Sky use encription by default, & the Chinese haven't paid for the license?
ArborealSeer
Wed Feb 01, 2012 12:50 pm
but it says it supports HDCP up to 1.2 at least..
the only thing i know about sky's hdmi is that it doesn't provide much power over HDMI.. at home I use an HDMI autoswitcher which will use power from HDMI to switch. I have had to add a power adapter to it it as the sky+ box doesn't give it enough juice.. whereas the xbox360, blu-ray player, both my laptops and desktop are fine with it
Pi Status > Farnell, Arrived 24/5- RS, Arrived 1/6
jcbbuk
Fri Feb 10, 2012 9:30 pm
Hi first posting here,
Check out below
http://fit-pc.co.uk/Fit_VGA_Co.....t--24.html
Uk and most likely world wide distr. around £30.
Not tried one yet.
