Nekoboy00
Where to connect my fan?
Thu Nov 28, 2019 1:28 pm
First of all, sorry for my english, it's not my native language bla...bla...
So, I have bought a case for my raspberrypi 4B, and that case includet a fan, and I would like to use it because the pi is getting kinda hot. And here comes the problem: I'm using an breadboard with GPIO Extension Board, means all of my 40GPIOs are sticked into an Ribbon cable... is there a way to get power for the fan from somwhere else? (I don't want to add an battery into the case because it have to be turned off all the time :/)
mahjongg
Re: Where to put my fan?
Thu Nov 28, 2019 2:34 pm
Not really without soldering.
If you can solder you can pick off +5V and GND from D1, the protection diode, to the top left of HDMI-0.
or use a "fan shim", which has a loop through connector for the GPIO header.
for example this one: https://www.kiwi-electronics.nl/pim-461 ... gJyJvD_BwE
Imperf3kt
Re: Where to connect my fan?
Thu Nov 28, 2019 9:21 pm
Do you have a spare usb port or a hub you can use? You can get 5v through that.
55:55:44:44:4C
52:4C:52:42:41
dustnbone
Thu Nov 28, 2019 10:01 pm
Or extend the fan leads out to the breadboard for now?
sgeorgerobert
Wed Dec 11, 2019 1:11 am
I was researching this exact issue. Like a previous poster mentioned, a USB port seems to be the best method. The fan shim that is currently available uses pins which may not be compatible with whatever else you're trying to connect.
I believe that a standard raspberry fan's pin connectors should be able to work in this...
https://www.amazon.com/3-Pin-Sleeved-Ad ... B07JW73KVR
Please inform me if that's some sort of mismatch.
