miky94
quality sound card and speaker for Pi 3/Pi Zero
Wed Nov 20, 2019 11:01 pm
I'm making a musical instrument using a Pi 3 and I'm looking for a better quality sound card and a speaker
requirements:
1 ) 70dB output that according to Wikipedia is EPA-identified maximum to protect against hearing loss and other disruptive effects from noise, enough to hear it outdoor from nearby people like a smartphone speaker
2 ) 3.5mm jack for headphones
3 ) portability, shouldn't be a problem I'll build a case around it, better if the speaker has circular shape
4 ) low battery consumption
5 ) I2S, better than USB
6 ) Pi Zero compatible, if resources won't be a problem it would be more suitable for portability
7 ) price, I won't spend $50 on a $35 computer
do you know anyone that meets the requirements?
an idea would be to output it from a smartphone via bluetooth, not sure about delay but I've seen other instruments using it, what do you think about?
thanks
W. H. Heydt
Re: quality sound card and speaker for Pi 3/Pi Zero
Wed Nov 20, 2019 11:04 pm
Some of your ideas are in conflict with each other. Notably, low power vs. high volume and sound quality vs. low cost. You might consider looking at the products from HiFiBerry.
miky94
Wed Nov 20, 2019 11:52 pm
I'm looking for a good compromise, I don't need too high volume and too good sound quality, I described the key points
from HiFiBerry do you mean a particular product? I didn't find something with integrated speaker
what about using a smartphone as bluetooth speaker?
dustnbone
Thu Nov 21, 2019 12:28 am
The most economical is going to be just finding a bluetooth speaker that meets your needs/budget. You're not going to get anything hifi for your budget, if you want that it's going to cost a bit more.
There's nothing Pi specific about this really, unless you're talking about using dedicated addon DAC boards but those are all going to be far above your budget, and a bit of a waste if all you're going to be feeding the signal to is a cheap loud mono speaker.
There are also integrated USB Speakers that appear to the computer as a USB sound card, any of those should also work as they all just use the USB Audio standard which is supported by Raspbian.
I can't really help recommend any of the above as I'm pretty picky when it comes to audio. I broke your "not spending $50 on a $35 computer" rule quite badly and have a $150 USB DAC plugged into my Pi for audio purposes, and to that I have connected a set of powered studio monitors. It sounds pretty fantastic, the DAC doesn't seem to care how much the computer it's plugged into cost.
miky94
Thu Nov 21, 2019 1:02 am
for the prototype I'm not looking to a really hifi solution in fact I was thinkinh about using a smartphone
the instrument will only play .wav samples using pygame, I'm just looking for something better than the unportable computer USB speaker I have, for sure in the future I'll look to something more hifi oriented
bertlea
Thu Nov 21, 2019 2:50 am
@miky94, Pimoroni got some new audio stuff you may be interested in (see the link below). One of them have a 3W (per channel) audio output but I am not sure if it can output 70dB as I am not familiar with audio stuff.
https://shop.pimoroni.com/collections/pirate-audio
HawaiianPi
Thu Nov 21, 2019 2:55 am
If you want to drive speakers to any kind of reasonable volume you'll need amplification. Computer speakers are usually amplified. Home audio speakers usually are not (there are exceptions, of course, like google or amazon smart speakers).
Adding audio_pwm_mode=2 to config.txt will enable higher quality analog audio out of the Pi3's 3.5mm jack.
The Pi Zero has no analog audio out (digital audio outputs through the HDMI port), but it can be added with a few inexpensive components on the GPIO (you'll still need amplification for speakers).
Computer speakers are usually amplified, and are available in a wide variety of sizes, configurations and price points.
However, the suggestion from dustnbone of using a Bluetooth speaker would be the simplest. A portable Bluetooth speaker should work with any wireless Pi model (such as the Pi Zero W). It would already include a battery for power in a nice, portable enclosure. You could build your instrument however you wanted and just set the speaker down wherever it's convenient to use (doesn't need to be integrated).
Oh, and since a Bluetooth speaker would be useful with your phone and other devices, the "I won't spend $50 on a $35 computer" budget doesn't necessarily apply (justification, in case you find a more expensive one you really want).
miky94
Thu Nov 21, 2019 3:30 am
@bertlea I don't know hot to calculate output dB, maybe someone can help
@HawaiianPi what does audio_pwm_mode=2 does and why is it not default?
Thanks for all your answers, I'd go for a bluetooth speaker hoping there is not too much delay, but before I want to try to use the smartphone as speaker, I don't know if anyone has already done it, a first search gave me only the opposite (Pi as bluetooth receiver for a speaker)
after some tests I'll ask you again for a hifi upgrade
Burngate
Thu Nov 21, 2019 10:41 am
You're getting into a highly complex area.
As a starter, have a look at https://en.wikipedia.org/wiki/A-weighting
How loud sound from a speaker sounds will depend on how far away your speaker is and your environment, as well as how efficient the speaker is.
So converting amplifier power output to dB(A) is never going to be straightforward
LTolledo
Thu Nov 21, 2019 11:04 am
For RPiZero class board, the JustBoom AmpZero, or the Pimoroni Pirate Audio , however these have no headphone jacks, just speaker outs.
For the RPi3B/3B+/4B class boards, the nearest to your requirements are the Suptronics X400 v2.0 or X400 v3.0, and needs to be powered 12v minimum.
RPi1B-X400v2 GPIO not covered.jpg (226.83 KiB) Viewed 523 times
or you can DIY yourself with:
a PCM5122 I2S DAC module and PAM8403 amp module on a RPi3 (or RPiZero) protoboard....
Some people be like:
miky94
Thu Nov 21, 2019 9:55 pm
I take this opportunity of your experience on Raspberry and audio to ask you if you know what this error means:
ALSA lib pcm.c:8306:(snd_pcm_recover) underrun occurred
it occurs sometimes and the program continues its execution but without audio, sometimes is followed by:
ALSA write failed (unrecoverable): Input/output error
I'm just using pygame to initialize a mixer with a channel, even if not playing anything
miky94
Fri Nov 22, 2019 12:30 am
I tried SoundWire http://georgielabs.net/ to output audio from the smartphone, but the quality was bad both from the smartphone and from the headphones, so I had to remove pulseaudio to return to the original, don't know if it is a configuration problem
melaniestaines
Fri Nov 22, 2019 12:08 pm
Thanks, i m also looking into this link to find something good.
