nick8967
GPIOs working in parallel
Wed Nov 06, 2019 10:27 pm
Can I have different GPIOs working in parallel.
For example can I have
GPIO 17 -----> working as input
GIPO 27 -----> working as input
GPIO 22 -----> working as output
at the same code? and nearly at the same time?
dickon
Re: GPIOs working in parallel
Wed Nov 06, 2019 10:33 pm
It would be pretty useless if you couldn't...
FTrevorGowen
Wed Nov 06, 2019 10:43 pm
nick8967 wrote: Hello,
Yes! FWIW here's an example: http://www.cpmspectrepi.uk/raspberry_pi ... alLCD.html
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
HermannSW
Thu Nov 07, 2019 2:56 pm
at the same code?
Yes, you can use C interface for pigpio library, you just register the same alert function for the GPIOs:
http://abyz.me.uk/rpi/pigpio/cif.html#gpioSetAlertFunc
In case every millisecond is "nearly the same time" for you, the yes. From above pigpio page:
The thread which calls the alert functions is triggered nominally 1000 times per second.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
PiGraham
Thu Nov 07, 2019 3:12 pm
You can certainly set au gpios as a mix of inputs and outputs.
What do you mean by "nearly at the same tme?
I should think any gpio library could configure three gpio in less than a millisecond.
It would be a very unusual application where normal methods are not adequate.
Why can't you configure step bu step as input, input, output?
If you need it faster than that I think GPIO are configured in banks by writing to control registers. Using that method all gpio pins controlled by the register are configured at the same time and discrepancies are probably in the nanosecond range.
Some libraries may allow register control from user code otherwise you may need to get low level to write the registers.
See:
https://elinux.org/RPi_GPIO_Code_Sample ... ter_access
hippy
Thu Nov 07, 2019 5:05 pm
Yes, very nearly at the same time.
The only things one cannot do simultaneously, because of the internal architecture of the chip, is simultaneously turning on a pin while turning another off, or reading the pins while turning others on or off, or vice-versa, but all those things can be done separately in incredibly fast succession.
The programming language and libraries you use will likely dictate just how quickly you can do things in succession, but in most cases, if just talking about 'can I make a LED turn on and off when I push and release a button', the answer is yes.
