bomblord
If I put an updated Raspbian into an older Pi 4 will it update the firwmare?
Sun Nov 03, 2019 2:42 pm
That's really my only question. I have a primary Pi 4 and a secondary one both purchased around the same time. I use the secondary one for other OS's and experiments. If I move the SD with my fully updated Raspbian from my primary to my secondary will it update the firmware or do I need to do something to make it happen? Running apt-get update/upgrade doesn't seem to actually do anything when it's up to date even on an older pi.
Re: If I put an updated Raspbian into an older Pi 4 will it update the firwmare?
Sun Nov 03, 2019 3:02 pm
If it you don't have NOOBS 3.1.1 or Raspbian Buster 2019-06-20 (or later) on your SDCard it won't boot on your RPi4B and there's no simple (or supported) way to upgrade anything older.
This is a doctor free zone.
Kendek
Sun Nov 03, 2019 3:11 pm
I guess you want to update the bootloader and the VLI EEPROM to the latest stable versions. If the rpi-eeprom-update service is enabled, you will need to boot the Raspbian two times. The upgrade process will be performed at the second boot.
W. H. Heydt
Sun Nov 03, 2019 4:38 pm
He indicates that both are Pi4Bs, so he has to be running Buster on the one using Raspbian.
W. H. Heydt
Sun Nov 03, 2019 4:40 pm
At present, I don't believe that firmware updates are automatically done through the apt update/upgrade process. That is planned for the future. The way thing are now you'd have to explicitly tell the Pi to upgrade the firmware.
Sun Nov 03, 2019 4:49 pm
https://www.tomshardware.com/uk/feature ... twork-boot
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
bomblord
Mon Nov 04, 2019 12:58 pm
I've definitely received the update that unlocked the overclock multiplier that way.
W. H. Heydt
Mon Nov 04, 2019 3:56 pm
Changing the overclocking limit doesn't involve any firmware in the EEPROM.
bomblord
Mon Nov 04, 2019 10:02 pm
Alright
