During my initial attempts I was using the arm-linux-gnueabi compiler, which is available in the Ubuntu repo. I got this working. I was able to build all my dependencies and use the cross-compiler in my cmake project.
However, I believe I should be using the hf version, so I switched to arm-linux-gnueabihf. Then I realized that this does not work with Raspberry Pi since it is armv6.
After some Googling, I then found the pre-built toolchain from GitHub MyColes
I downloaded the toolchain, but I don't really understand how to "install" it. I extracted the files to my home directory. The directory structure looks like this:
/gcc-linearo-arm-linux-gnueabihf-raspbian
/arm-linux-gnueabihf
/bin
(contains g++, gcc, etc)
/lib
(contains libstdc++ library)
/bin
(contains arm-linux-gnueabihf-g++, arm-linux-gnueabihf-...)
/lib
(gcc lib stuff)
~/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/
arm-linux-gnueabihf/bin$ g++ test.cpp -o test
I then tried to compile a test program in the OUTER bin folder, which contains the prefixed versions of the tools.
~/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin$
arm-linux-gnueabihf-g++ test.cpp -o test
However, when I try to use the compiler now (from outside the inner bin directory), it is unable to find the libstdc++ shared library that comes with the toolchain:
arm-linux-gnueabihf-gcc: error while loading shared libraries:
libstdc++.so.6: cannot open shared object file: No such file or directory.
Furthermore, I want to be able to use the compiler without having to navigate to the bin directory. So I tried adding the OUTER bin directory (since I want the prefixed versions) and both lib directories to my PATH:
export PATH=$PATH:~/tools/.../bin
export PATH=$PATH:~/tools/.../lib
export PATH=$PATH:~/tools/.../.../lib
