External hard drives that no longer standby under rasbian buster
Posted: Sat Oct 19, 2019 7:16 pm
by Gilder
Good evening, I use a RPI 3b+ like nas with 3 hard drives connected in USB and where each disc is in a box which is supposed to extinguish automatically the disc after 10 minutes of inactivity. Everything worked well before, but since the passage to raspian 10, it does not seem to work, and I hear all the time the discs turn any time of the day. An idea of how to solve that?
Even when I dismount a disc, it does not go to sleep
Re: External hard drives that no longer standby under rasbian buster
Posted: Sat Oct 19, 2019 8:42 pm
by epoch1970
Did you check with the "mount" command that the device is not mounted still?
Your OS is running off the SD, or one of the drives?
Posted: Sat Oct 19, 2019 9:04 pm
by Gilder
you can look at the result of the command "mount" and "lsblk" . And yes , raspbian is installed on the SD card
Posted: Sat Oct 19, 2019 10:20 pm
by andrum99
sudo apt update && sudo apt install hdparm
sudo hdparm -q -S 120 -y /dev/sda
You can also put calls to hdparm in /etc/rc.local to set the standby timeout at boot - works for me. See 'man hdparm' for details.
Posted: Sat Oct 19, 2019 10:22 pm
by Kendek
If installed, hdparm automatically sets the APM level to 254 on all HDDs by default, and there is no spin-down from value 128.
You can edit the /etc/hdparm.conf, just uncomment the spindown_time line, and set value to 120, which is 10 minutes.
You can test it with the following command:
sudo DEVNAME=/dev/sda /lib/udev/hdparm
Posted: Sun Oct 20, 2019 11:44 am
by Gilder
I did that and now it works. But why 120 = 10 minutes? what is this 120?
Posted: Sun Oct 20, 2019 11:51 am
by Kendek
You are welcome. Values from 1 to 240 specify multiples of 5 seconds, so 120 x 5 = 600 seconds, which is 10 minutes.
Posted: Sun Oct 20, 2019 3:48 pm
by andrum99
Yup - It's explained in the man page for hdparm. I'm guessing it has to do with the way the timeout is encoded in the hard drives themselves - they've used a single byte to represent the standby timeout setting - 0 to 255 - and some clever maths to enable this to specify values up to several hours.
