david_1234
how to fix " 'apt --fix-broken install" error?
Tue Oct 15, 2019 7:19 am
I'm trying to watch netfilx on pi
and did everything is say on this guide :
https://thepi.io/how-to-watch-netflix-o ... pberry-pi/ but it doesn't wrok - and I get this error
Error Code: C7121-1331
when I look for a solution - first thing was to run
apt get update && upgrad
e
but now I get this error:
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 chromium-browser-l10n : Depends: chromium-browser (>= 72.0.3626.121-0+rpt4) but 56.0.2924.84-0ubuntu0.14.04.1.1011 is installed
 rpi-chromium-mods : Depends: chromium-browser (>= 65) but 56.0.2924.84-0ubuntu0.14.04.1.1011 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
what do I need to do?
up until now I didn't have this problem
Thanks ,
p.s
if someone have a working updted guide to watch netflix - I will love to get it :-)
Thanks ,
dickon
Re: how to fix " 'apt --fix-broken install" error?
Tue Oct 15, 2019 7:57 am
I realise that this may come as a bit of a shock, but if you run
the problem just might be corrected.
david_1234
Tue Oct 15, 2019 11:28 am
:roll: :roll: :roll: :roll: :roll:
thanks.
didn't help - netflix is still show me error
I will lokk for another guide
bjtheone
Tue Oct 15, 2019 8:05 pm
You likely have library issues plus Netflix is doing something goofy with DRM and blessed platforms. I recently used this method to get Spotify running and it still works with a fully up to date (as of yesterday) system.
https://blog.vpetkov.net/2019/07/12/ne ... chromium/
david_1234
Wed Oct 16, 2019 8:18 am
I have done everything is said in the guide
in the demo webpage I saw the demo movie running , also it said that he detect the and unsing Widvine
when I enter netflix I can see the trailer running in the background ,
but when I want to see the movie I get this error:
This title is not available to watch instantly. Please try another title.
For additional assistance in resolving this issue, please visit our Help Center.
Error Code: M7121-1331
any idea why?
what else I can do ?
I'm using pi3 (but I don't think it should be the problem)
Thanks ,
davidcoton
Wed Oct 16, 2019 8:34 am
So, have you tried visiting the Netflix Help Center?
Signature retired
david_1234
Wed Oct 16, 2019 9:25 am
yes ,
they say to remove all the chrome extensions
and if it's not helping - to reinstall the chrome
I have done all this before - didn't help
rpdom
Wed Oct 16, 2019 9:29 am
You might get more appropriate replies if you edit the subject line on your first post and change it from "how to fix 'apt --fix-broken install' error?" to "How to get netflix working with Chrome browser?"
(No, I don't know how to get Netflix working, I just think this may get different people to read your post)
Wed Oct 16, 2019 9:53 am
e
Thanks ,
p.s
Thanks ,
The guide you are following is way out of date, mentions chromium-browser 56, we are now on version 74. If it does not specifically state Raspbian Buster give up following any guide.
There was a recent post in these forums:
https://www.raspberrypi.org/forums/view ... p?t=243900
Retired disgracefully.....
melisa
Thu Oct 17, 2019 3:45 am
Hi david,
Before this i get problem, and i used this solution. You can try.
After trying
sudo apt-get update –fix-missing and sudo dpkg –configure -a and sudo apt-get install -f
the problem of a broken package still exist the solution is to edit the dpkg status file manually.
$ sudo nano /var/lib/dpkg/status (you can use vim or gedit instead of nano)
Locate the corrupt package, and remove the whole block of information about it and save the file.
Unlock the dpkg – (message /var/lib/dpkg/lock)
sudo fuser -vki /var/lib/dpkg/lock
For 12.04 and newer:
You can delete the lock file with the following command:
sudo rm /var/lib/apt/lists/lock
You may also need to delete the lock file in the cache directory
sudo rm /var/cache/apt/archives/lock
david_1234
Thu Oct 17, 2019 5:43 am
the version of the chrom is 72 and can't be upadte
I will start a new post
Thanks ,
Thu Oct 17, 2019 6:11 am
Thanks ,
You are running the latest supported Raspbian Buster ???
