Determining Pi serial number
Posted: Fri Oct 11, 2019 10:05 pm
by ctrygstad
It looks like there are a number of ways to get it by going into the operating system, but is serial number printed somewhere on the board? To confirm, trying to working with the Raspberry Pi 3 B+
Re: Determining Pi serial number
Posted: Fri Oct 11, 2019 10:12 pm
by DavidCoder
Sorry, but the serial number can only be found from the pi interface, not printed on the pi as far as I know. I'm sorry for the inconvenience. :(
Posted: Fri Oct 11, 2019 10:15 pm
by Andyroo
Just be aware they are not unique :shock:
Due to the number being made the chance of getting two the same is very very small...
Posted: Fri Oct 11, 2019 11:18 pm
by trackseven
I found this in another post
# revised 08-17-2019
#!/usr/bin/python3
#                mypi.py
#  Functions to display Pi properties
#  If called directly outputs :
#  - Pi Model
#  - Revision number
#  - Serial number
#  - Python version
#  - I2C,SPI and Bluetooth status
#  - Mac address
#  - IP address
#  - CPU temperature
#  - GPU temperature
# Author : Matt Hawkins
# Date   : 06/12/2017 Revised 08-17-2019 for my Pi Zero W (by kflmiami420)
# https://www.raspberrypi-spy.co.uk/
import platform
import subprocess
import os
import socket
from uuid import getnode as get_mac
# Define functions
def getModel():
  # Extract Pi Model string
  try:
    mymodel = open('/proc/device-tree/model').readline()
  except:
    mymodel = "Error"
  return mymodel
def getSerial():
  # Extract serial from cpuinfo file
  mycpuserial = "Error"
  try:
    f = open('/proc/cpuinfo','r')
    for line in f:
      if line[0:6]=='Serial':
        mycpuserial = line[10:26]
    f.close()
  except:
  return mycpuserial
def getRevision():
  # Extract board revision from cpuinfo file
  myrevision = "Error"
  try:
    for line in f:
      if line[0:8]=='Revision':
        myrevision = line[11:-1]
    f.close()
  except:
  return myrevision
def get_local_ip_address(target):
  ipaddr = ''
  try:
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    s.connect((target, 8000))
    ipaddr = s.getsockname()[0]
    s.close()
  except:
    pass
  return ipaddr
def getCPUtemp():
  # Extract CPU temp
  try:
    temp = subprocess.check_output(['vcgencmd','measure_temp'])
    temp = temp[5:-3]
  except:
    temp = '0.0'
  temp = '{0:.2f}'.format(float(temp))
  return str(temp)
def getGPUtemp():
  # Extract GPU temp
  try:
    temp = subprocess.check_output(['cat','/sys/class/thermal/thermal_zone0/temp'])
    temp = float(temp)/1000
  except:
    temp = 0.0
  temp = '{0:.2f}'.format(temp)
  return temp
def getRAM():
  # free -m
  output = subprocess.check_output(['free','-m'])
  lines = output.splitlines()
  line  = str(lines[1])
  ram = line.split()
  # total/free
  return (ram[1],ram[3])
def getDisk():
  # df -h
  output = subprocess.check_output(['df','-h'])
  disk  = line.split()
  # total/free
  return (disk[1],disk[3])
def getCPUspeed():
  # Get CPU frequency
  try:
    output = subprocess.check_output(['vcgencmd','get_config','arm_freq'])
    output = output.decode()
    line  = lines[0]
    freq = line.split('=')
    freq = freq[1]
  except:
    freq = '0'
  return freq
def getUptime():
  # uptime
  # tupple uptime, 5 min load average
  return 0
def getPython():
  # Get current Python version
  # returns string
  pythonv = platform.python_version()
  return pythonv
def getSPI():
  # Check if SPI bus is enabled
  # by checking for spi_bcm2### modules
  # returns a string
  spi = "False"
  try:
    c=subprocess.Popen("lsmod",stdout=subprocess.PIPE)
    gr=subprocess.Popen(["grep" ,"spi_bcm2"],stdin=c.stdout,stdout=subprocess.PIPE)
    output = gr.communicate()[0]
    if output[:8]=='spi_bcm2':
      spi = "True"
  except:
    pass
  return spi
def getI2C():
  # Check if I2C bus is enabled
  # by checking for i2c_bcm2### modules
  # returns a string
  i2c = "False"
  try:
    gr=subprocess.Popen(["grep" ,"i2c_bcm2"],stdin=c.stdout,stdout=subprocess.PIPE)
    if output[:8]=='i2c_bcm2':
      i2c = "True"
  except:
    pass
  return i2c
def getBT():
  # Check if Bluetooth module is enabled
  # returns a string
  bt = "False"
  try:
    gr=subprocess.Popen(["grep" ,"bluetooth"],stdin=c.stdout,stdout=subprocess.PIPE)
    if output[:9]==b'bluetooth':
      bt = "True"
  except:
    pass
  return bt
if __name__ == '__main__':
  # Script has been called directly
  myRAM = getRAM()
  myDisk = getDisk()
  host = socket.gethostname()
  mac = get_mac()
  macString = ':'.join(("%012X" % mac)[i:i+2] for i in range(0, 12, 2))
  print("----------------------------------------")
  print("Pi Model             : " + getModel())
  print("Host                 :", host)
  print("System               : " + platform.platform())
  print("Revision Number      : " + getRevision())
  print("Serial Number        : " + getSerial())
  print("Python version       : " + platform.python_version())
  print("I2C enabled          : " + getI2C())
  print("SPI enabled          : " + getSPI())
  print("Bluetooth enabled    : " + getBT())
  print("CPU Clock            : " + getCPUspeed() + "MHz")
  print("CPU Temperature      : " + getCPUtemp() + u"\u00b0" +"C")
  print("GPU Temperature      : " + getGPUtemp() + u"\u00b0" +"C")
  print("RAM (Available)      : " + myRAM[0] + "MB (" + myRAM[1] + "MB)")
  print("Disk (Available)     : " + myDisk[0] + " (" + myDisk[1] + ")")
  print("Wireless IP Address  : " + get_local_ip_address('10.0.1.1'))
  print("Wireless MAC Address : " + macString )
Posted: Sat Oct 12, 2019 7:42 am
by B.Goode
# sample code suppressed from this reply
So that is an example of "ways to get it by going into the operating system"
But the real question was " is serial number printed somewhere on the board?"
To which I believe, as with the first reply given, the answer is No.
Posted: Sat Oct 12, 2019 8:44 am
by DougieLawson
The answer is absolutely "no".
The serial is written to the OTP bits during manufacture (may be different on a 4B) and is only internal to the hardware, it is not externalised on any kind of sticker or ink jet printing.
Search Google there's a hundred and one ways to get the serial.
I like the three methods that Andrew Duncan has at: https://github.com/AndrewFromMelbourne/ ... rialnumber
There's even one that didn't exist before device tree /sys/firmware/devicetree/base/serial-number (that file has no new line, but it's a simple file read with no parsing needed).
Posted: Mon Oct 14, 2019 3:44 pm
by ctrygstad
Thanks, to confirm it was the Raspberry Pi 3 B+ model. All signs point to the fact that you have to login to the device to get the serial number, and there is a chance (although small), that you could have two devices with the same serial number.
Posted: Mon Oct 14, 2019 4:27 pm
by jamesh
Correct.(the chance is vanishingly small - they are very big pseudo random numbers)
