Andybp
running the system (a pi4b) off of ssd, will it give speed improvements?
Sat Sep 28, 2019 9:50 am
Hi. I’m toying with the idea of running the system (a pi4b) off of ssd. Just wondered what people’s views were of the general speed improvements are within raspbian. I know it’s dependant on the application. I mainly use it for scratch, chromium(bit of browsing, bit of YouTube), and toying with python.
Any views from others on general usability improvements would be great to hear, if indeed there are any.
clicky
Re: Ssd
Sat Sep 28, 2019 10:30 am
It makes visible difference.
Re: Ssd
Sat Sep 28, 2019 10:53 am
You will need a USB3 Caddy or similar to use a SSD Drive.
At present boot from a USB Mass Storage Device is not yet supported, though can boot off the SD Card and hand off to the USB MSD.
Many posts on this subject, but yes a USB MSD should make a noticeable improvement.
Retired disgracefully.....
Kendek
Re: Ssd
Sat Sep 28, 2019 10:55 am
A good SSD is much faster than an SD card in Pi, if connected through USB 3.x. Especially with UASP and TRIM/UNMAP support.
clicky
Re: running the system (a pi4b) off of ssd, will it give speed improvements?
Sat Sep 28, 2019 12:20 pm
Oh, forgot to include statistics:
$ sudo hdparm -t /dev/sda
/dev/sda:
 Timing buffered disk reads: 1050 MB in  3.00 seconds = 349.47 MB/sec
SSD ~ 2.7Gbit/s
Andybp
Sat Sep 28, 2019 1:23 pm
Thanks everyone. Over to amazon me thinks :-)
bjtheone
Sat Sep 28, 2019 1:33 pm
One note of caution, the Pi 4 does not seem to play nicely with some USB 3.0 - SATA adapters. It is worth while to either just buy one that others have claimed works or get it from somewhere with a decent return policy. Beyond that I would echo what everyone has already said, SSD provides a noticeable improvement, and is a more durable storage media.
clicky
Sat Sep 28, 2019 3:11 pm
Due to RPi size I would recommend M.2 with an adapter. Also, there are B, B+M and M key M.2 adapters. It seems that B and B+M are cheaper than M key only. Also, M key are faster but I am not sure if you're going to see any improvements due to USB3 (and RPi USB3) limitations.
Andybp
Sun Sep 29, 2019 5:16 pm
I bought a wd 120gb ssd. Only cost twenty quid. Then another 6 quid for an enclosure and cable. I’ll be giving it a go later. Never even occurred to me to go the m.2 route.
Ssd’s have gotten sooo cheap. Well chuffed
jerrm
Re: Ssd
Sun Sep 29, 2019 5:29 pm
Have you found an USB3 adapter for the pi that supports both UASP and TRIM?
Kendek
Re: Ssd
Sun Sep 29, 2019 5:55 pm
All StarTech products with ASMedia ASM1351 chip. Just install the firmware update.
I'm using cable-style adapters, and with the official firmware 150708B10103 the UASP and the TRIM/UNMAP are working well.
Lsusb:
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
    |__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
Udev rule:
ACTION=="add|change", ATTRS{idVendor}=="174c", ATTRS{idProduct}=="55aa", SUBSYSTEM=="scsi_disk", ATTR{provisioning_mode}="unmap"
Trim:
> dmsetup table --showkeys
data: 0 3906996400 crypt xchacha12,aes-adiantum-plain64 :32:logon:cryptsetup:c4368a29-28ae-4c6b-8746-1045619b272d-d0 0 8:0 32768 2 allow_discards sector_size:4096
> fstrim -av
/data: 0 B (0 bytes) trimmed on /dev/mapper/data
jerrm
Re: Ssd
Sun Sep 29, 2019 6:58 pm
Will it complete the a bonnie benchmark without any errors in syslog?
sudo apt-get install bonnie++
sudo bonnie++ -u root -d /mnt/path/to/ssd
The "Rewriting" phase can break some adapters that otherwise seem OK.
Kendek
Re: Ssd
Sun Sep 29, 2019 7:28 pm
It's an SMR HDD, 2.5" WD WD20SPZX:
> bonnie++ -u root -d /data
Using uid:0, gid:0.
Writing a byte at a time...done
Writing intelligently...done
Rewriting...done
Reading a byte at a time...done
Reading intelligently...done
start 'em...done...done...done...done...done...
Create files in sequential order...done.
Stat files in sequential order...done.
Delete files in sequential order...done.
Create files in random order...done.
Stat files in random order...done.
Delete files in random order...done.
Version  1.98       ------Sequential Output------ --Sequential Input- --Random-
                    -Per Chr- --Block-- -Rewrite- -Per Chr- --Block-- --Seeks--
Name:Size etc        /sec %CP  /sec %CP  /sec %CP  /sec %CP  /sec %CP  /sec %CP
RPI4          7592M  180k  99 90.4m  39 45.6m  21  855k  92 96.3m  22 208.7  11
Latency             82638us    2725ms    4015ms     274ms   78567us    2034ms
Version  1.98       ------Sequential Create------ --------Random Create--------
RPI4                -Create-- --Read--- -Delete-- -Create-- --Read--- -Delete--
              files  /sec %CP  /sec %CP  /sec %CP  /sec %CP  /sec %CP  /sec %CP
                 16 -375137312  84 +++++ +++ -375137232  86 -375137192  87 +++++ +++ -375137112  86
Latency               293us     674us     936us    1306us      65us    1313us
1.98,1.98,RPI4,1,1569785861,7592M,,8192,5,180,99,92596,39,46669,21,855,92,98608,22,208.7,11,16,,,,,19228,84,+++++,+++,23974,86,20649,87,+++++,+++,22414,86,82638us,2725ms,4015ms,274ms,78567us,2034ms,293us,674us,936us,1306us,65us,1313us
I don't see any related error message in the syslog, only this:
Sep 29 21:11:03 RPI4 smartd[333]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 108 to 106
Which is remind me to disable the smartd, thanks! :D
jerrm
Re: Ssd
Sun Sep 29, 2019 10:45 pm
I don't see any related error message in the syslog...
Good to know. I'll order one and see how it goes.
I had a another ASM1351 adapter sitting around that I tried the StarTech firmware on, but it the update utility wouldn't work on it. Didn't really expect it to - device id was 174c:1351 instead of 174c:55aa .
Been holding off the StarTech of because of the price premium. It's an additional $15-$20 narrowing the gap to an Atom or Celeron solution that "just works" with more adapters.
Kendek
Re: Ssd
Mon Sep 30, 2019 5:20 am
The StarTech's updater doesn't work, but I've extracted the 150708_B1_0A_02.bin. You can download it from here, just use the MPTool_2.2.0.0.exe. Only thing, maybe your LED won't functional with this firmware.
