qaz
Show splash screen ASAP
Sun Sep 15, 2019 10:02 am
I'd like to show splash screen as soon as possible at boot time (I'm using Raspbian Stretch Lite).
At the moment I'm using default Plymouth splash screen (using this guide: https://www.thedigitalpictureframe.com/ ... 9-version/)
And it takes around 14sec from power on to show up.
Compared to RetroPie splash screen that only takes 4sec to show.
Can anyone teach me how to do it?
Thanks in advance
qaz
Re: Show splash screen ASAP
Sun Sep 15, 2019 3:38 pm
Shoud I have posted to a specific forum? :?
W. H. Heydt
Sun Sep 15, 2019 3:50 pm
No... But you should have waited a lot more than 5 hours before bumping your post.
B.Goode
Sun Sep 15, 2019 3:59 pm
Everything you post goes in a specific forum of your choice.
In this case, Community -> General discussion.
If you feel it is more appropriate elsewhere, such as Operating Systems -> Raspbian, then use the Report This Post facility to ask a Moderator to relocate it. Don't duplicate it.
If your underlying concern is that you have not had a reply after 5 hours of waiting then be aware that most advice here comes from volunteer helpers donating their free time - maybe the person with the skill and inclination to help has not logged in yet. It is a weekend where I live.
(Pretty much what @whh said more pithily as I was writing this... )
qaz
Sun Sep 15, 2019 4:24 pm
dkeruza
Thu Sep 19, 2019 3:03 pm
Thanks in advance
I have the same issue in a Raspberry pi Zero w, were you able to solve it?
DarkElvenAngel
Fri Sep 20, 2019 2:04 am
You can use an initramfs to display an image within 1-2 seconds after boot. Depending on your setup and needs you can do away with Plymouth.
I have an older guild to achieve this here https://www.raspberrypi.org/forums/view ... 7#p1335189
pi-tastic
Fri Sep 20, 2019 3:37 pm
do you mean this option?
Screenshot from 2019-09-20 11-01-48.png (34.96 KiB) Viewed 271 times
maccaps.com - bringing life to dead electronics.
dkeruza
Sat Sep 21, 2019 2:51 am
This is a great guide. Thanks
One more question, I did install plymouth to have an animation as soon as the system boots, but I have the same problem, takes like 14 seconds to show up.
I did use initramfs for plymouth but seems like is still running from the main root volume.
Any suggestion to make the plymouth animation from the initramfs?
Thanks again
DarkElvenAngel
Sat Sep 21, 2019 11:59 am
Thanks again
Yes you can make Plymouth or anything really run from the initramfs. The problem is that programs have dependencies and they need to go in too or at least be available... Then there's the handover from initramfs to rootfs that might cause an issues. I'm working on a newer guide that better suits what you want to try.
I'm wondering what your project is meant to do does it boot into a custom ui or program? And what hardware are you using (Pi 0 is my guess) SD card speed.
These things will be helpful to get you from power on to application faster. In the meantime I'll look into testing if Plymouth will play will in initramfs.
dkeruza
Tue Sep 24, 2019 10:04 pm
Thanks again
I believe that I am missing a dependency in my initramfs, that is why the plymouth animation starts when the rootfs is handed.
I am using a Pi zero W and is a project that boots and plays videos in a loop, which I was also thinking of just boot to initramfs which is extremely quick and play the videos from there, no need for a full system boot.
My goal would be to boot to a splash screen, then plymouth animation from initramfs. then either keep booting the complete os an start playing the videos or play the videos from the initramfs itself. Videos will be stored in an external USB drive.
Is there any way I can see which plymouth dependencies are missing?
Thanks and I wish I could make it work.
DarkElvenAngel
Thu Sep 26, 2019 9:23 pm
Very similar to what I've worked on. You can use Buildroot to build a full rootfs in the initramfs. I would advise against putting to much in there since memory resources are limited on a Pi Zero W.
As for Plymouth from what I read it should be able to run from the initramfs, you can find dependencies with the
ldd
command as far as binaries go. Maybe this Debian wiki page is useful https://wiki.debian.org/plymouth
Realistically you should be able to play a local video long before the system completes booting. have you disabled unneeded services from your boot? Networks are the slowest to start and you don't need to wait for it to start unless you need it.
