ryan810cows
Max USB Drives
Mon Aug 26, 2019 11:55 pm
Hello Pi World!
I'm VERY new and am wanting to get into the world of PI!
I will be getting (2) PI4's soon.
(1) will be a RetroPi
(1) will be a Backup NAS to my FreeNAS server
Here comes the question.....
Specifically talking about the Backup NAS...
If I get this 7-port USB Hub (https://t.ly/y2xnD), will the PI4 be able to recognize all (7) ports *PLUS MORE*?
I will be using this HDD rack to hold (5) drives at first.. later I plan to add (5) more (https://t.ly/RpJZ3).
I will use this SATA to USB (https://t.ly/YdExJ) and I will power each HDD on the rack by a PC Power supply.
So.. what do you think? Keep in my, i don't care about x-fer speed, this is just a file storage backup that will run (1 to 2 times a week).
Your thoughts are MOST appreciated!
topguy
Re: Max USB Drives
Wed Aug 28, 2019 12:12 pm
Max number of USB devices connected to any computer ( afaik ) is 127 but also counting all USB-hubs.
ryan810cows
Re: Max USB Drives
Wed Aug 28, 2019 12:26 pm
THANK YOU!! :D Just what I needed to know!
Re: Max USB Drives
Wed Aug 28, 2019 1:33 pm
The Pi 0-3 had a limit of something like 6 USB endpoints. The Pi 4B uses a different USB system and supports up to 32 devices (see here: https://www.raspberrypi.org/forums/view ... 5#p1484595)
ryan810cows
Re: Max USB Drives
Wed Aug 28, 2019 1:40 pm
That will still work VERY well for my needs!
Thanks for the help guys!
scruss
Re: Max USB Drives
Wed Aug 28, 2019 1:51 pm
All the devices you list — well, the hub and the USB→SATA adapter — are USB 2. This negates any advantage of using a Raspberry Pi 4. I know you said you didn't care about speed, but your once or twice per week backup might still be backing up the next time you want to do it.
ryan810cows
Re: Max USB Drives
Wed Aug 28, 2019 2:15 pm
I have thought about that a good bit and for now i'm willing to take the chance.
By using the PI4 is sounds like i will get 32 devices instead of just 6 (if i understood that correctly b/t the 3 vs. 4) - so that's a big plus
I'm also hoping the increase in ram and processor speed will help any "computing" i may need later down the road.
But yes, it will still run at 2.0 and i'm hoping it will be fast enough for just a secondary backup.
Thank for the input though!
trejan
Re: Max USB Drives
Wed Aug 28, 2019 2:38 pm
You'll be able to have a lot of HDs but IIRC USB hubs count towards the 32 devices. I'd be wary about going right up to the limits as well.
ryan810cows
Re: Max USB Drives
Wed Aug 28, 2019 3:06 pm
Understood and I agree. Not pushing the limits.
I plan to have no more then (10) HDD's and (2) USB-7port Hubs = 12 connected devices.
I should be OK..... theoretically!! :shock:
dmikester1
Re: Max USB Drives
Wed Aug 28, 2019 3:26 pm
Doesn't the Pi 4 have usb 3.0? Why wouldn't you get a 3.0 hub?
FTrevorGowen
Re: Max USB Drives
Wed Aug 28, 2019 3:27 pm
However, IIRC, so-called "7-port hubs" are two 4-port hubs "in series" ie. hub1 port4 feeds/connects to the input of the second hub. Also, as far as USB-2 hubs are concerned, unless things have changed, be wary of (the cheap versions of) something like this:
http://www.cpmspectrepi.uk/raspberry_pi ... rtHub.html and the associated measurements here: http://www.cpmspectrepi.uk/raspberry_pi ... st_Results (or rather, any "included" PSU)
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
RaTTuS
Re: Max USB Drives
Wed Aug 28, 2019 3:33 pm
10 HD,
your pushing a lot of things here
you can get 14TB Drives , or 10TB or even 4TB -
6x 4TB is plenty for anything .... [ha]
Covfefe
ryan810cows
Re: Max USB Drives
Wed Aug 28, 2019 3:38 pm
Understood.
But i have FREE 500 gb HDD's from work b/c we change them out so often as a preventive measure and most of the time they are happy and healthy still.
That would be me at 5 tb of storage in total if i just use them as individual HDD's and not do any RAID.
drgeoff
Re: Max USB Drives
Wed Aug 28, 2019 3:44 pm
Trev.
Indeed, I had one of those briefly in 2012 (when the original RPi was launched) but returned it because of the included PSU (UK 3-pin). Wouldn't give much more than 0.5 amps before the voltage began to fall significantly. There was also a youtube video where someone demonstrated the same failing and also opened it up and found several safety concerns.
Edit. found the video. https://www.youtube.com/watch?v=T88ej64aXUM
clicky
Re: Max USB Drives
Wed Aug 28, 2019 4:13 pm
Understood.
Just imagine you do have some fancy self healing/triple redundant/hot pluggable raid... :D
With all the free HDs...
