Page 2 of 2
Re: Fixing the Pi 4 usb C issue by hand
Posted: Thu Nov 14, 2019 1:24 pm
by Imperf3kt
procount wrote:
Thu Nov 14, 2019 11:01 am
Or maybe just add 2 back to back adaptors:
Usb-c/micro-usb -> micro-usb/usb-c.?
I can confirm that USB-C cables do not appear to work when used like that.
(I've tried)
Posted: Thu Nov 14, 2019 2:49 pm
by procount
Thanks for confirming it doesn't work. It was a suggestion someone made to me.
I guess it depends on whether the USB-C/micro adaptor contains the necessary cc resistors for power delivery. Often they don't say.
Posted: Thu Nov 14, 2019 3:31 pm
by emma1997
hippy wrote:
Thu Nov 14, 2019 11:00 am
I doubt any company would create an adaptor for commercial sale as it would probably be too costly given the small market for such a board
What do you mean 'small market'? There have to be at least 3 individuals here in the US alone desperate for such a solution. Considering design and tooling should be able to produce such an item for as little as $200-$300 per. lol
I think there was a Shakespeare play on the subject: Much Ado About Nothing?
Posted: Fri Nov 15, 2019 12:41 am
by Imperf3kt
Stopping and thinking about it for a moment, a smart charger is supposed to default to just supplying 5v if it's plugged into a non smart device. At least, it does with micro USB.
What would happen if someone was to take a USB-C cable and only connect the vcc and GND wires into the Pi with something like this?
https://core-electronics.com.au/micro-u ... -pi-4.html
Posted: Fri Nov 15, 2019 7:32 am
by supersjimmie
What I meant with the usb-c male/female could also be done with something like this:
https://www.aliexpress.com/item/33005988619.html
Then do exactly the same with adding one 5.1k resistor on te same pin.
That should work?
Or easier to compose, but less pretty:
https://www.aliexpress.com/item/4000026719770.html
Posted: Fri Nov 15, 2019 8:19 am
by clicky
Brilliant! :D
Posted: Fri Nov 15, 2019 8:35 am
by HawaiianPi
supersjimmie wrote:
Thu Nov 14, 2019 9:30 am
Instead of having to modify the rPI4 board, would it be possible to add the 5.1k resistor inbetween a male/female usb-c connector?
That way we can have just a small converter-cable with the resistor instead of the risk of ruining the rpi4 board.
Power adapter USB-C -> diy USB-C [male] -> diy cable with resistor -> USB-C [female] -> RPi4
Sure, that would probably work, assuming you made the correct connections, but I've got as even easier and less risky solution...
Just buy the official power supply. :roll:
Posted: Fri Nov 15, 2019 9:57 am
by davidcoton
Somewhere here there is a thread that discussed how to modify a cable. Remember it has to work with both orientations of the plug. IIRC a one-resistor modification in the Pi end plug would work. Of course, the cable/adaptor is now useless for anything else. If you really need to use a smart charger, the mod to the Pi itself is as easy (not that easy, but within the scope of a competent amateur solderer) and saves having to buy extra kit (extra power connectors are in themselves a Bad Thing ™). If you don't want to modify your Pi, Just buy the official power supply.
Posted: Fri Nov 15, 2019 10:00 am
by supersjimmie
Sure, but that won't answer the title of this discussion.
Posted: Fri Nov 15, 2019 10:12 am
by jamesh
No, but it will be cheaper.
Posted: Fri Nov 15, 2019 10:22 am
by HawaiianPi
Already been answered. Was there some other answer you were looking for?
Posted: Thu Dec 26, 2019 5:43 pm
by procount
(I've tried)
@imperf3kt - Despite your experience, I decided to buy a pair of USB-C socket to micro-USB plug adaptors and tried one with my microUSB socket to usb-C adaptor. I chose these Arktek one's from Amazon (https://www.amazon.co.uk/ARKTEK-female- ... B071W8WQBD)
One of the adaptors was faulty, and wouldn't even work as a MicroUSB charger.
However, the other one worked fine back-to-back and allowed a USB-C PD charger to power my PI4.
So, it seems it would depend on the characteristics of the adaptor you use and specifically whether it includes the 2 CC resistors to tell the PD charger to deliver power.
Posted: Thu Dec 26, 2019 10:02 pm
by Imperf3kt
Nice to know.
I would mention the adaptor I have appears to includes some electronics.
This is the exact one I purchased.
https://www.bunnings.com.au/antsig-usb- ... k_p4360482
Posted: Mon Feb 24, 2020 2:16 am
by energyi
W. H. Heydt wrote:
Tue Aug 27, 2019 7:18 pm
spooker wrote:
Tue Aug 27, 2019 7:23 am
Do we have any idea when rpi4 revision 2 that will fix this major flaw will be available?
The flaw is minor, so there's no hurry. I doubt the change will result is a Rev. 2 of the PCB. More likely to be 1.1 or 1.2, or even 1.0.1. I do not, personally, expect to see a revised board for about 6 months. Could be sooner, could be longer. It all depends on whether or not any other board corrections are found that need to be done and how urgent they are.
Just about exactly 6 months.
