power supply raspberry pi 3 b+
Posted: Sat Aug 24, 2019 8:18 pm
by matteocamper
Hi everyone,
I am going to buy a raspberry pi 3 b+, I wanted to know if I could use the samsung normal charging power supply which outputs 5V and 2A. Can I use it without creating problems? (the pi would use it for openmediavault)
Re: power supply raspberry pi 3 b+
Posted: Sat Aug 24, 2019 8:51 pm
by Andyroo
Unlikely but possible.
Chargers can drop the voltage down to 4 and a bit volts to maintain the current and this will crash the Pi.
You may get away with it but find issues with Ethernet / WiFi (as I did with a 2.1amp supply).
Honestly, it’s a lot simpler for your future use to spend the few pounds on the correct Pi supply.
Posted: Sat Aug 24, 2019 9:02 pm
by LTolledo
is there something in the RPi3B+ that needs charging? (hint: understand the definition/meaning of "charging")
do a little bit more research on this then come back to answer
if there is any then by any means yes, use your charger
if there is none then get a proper power supply with the microUSB cable rated at least 20AWG (0.75mmsq)
Posted: Sat Aug 24, 2019 9:04 pm
by Andyroo
:lol:
Posted: Sun Aug 25, 2019 2:37 am
by W. H. Heydt
There are capacitors on the board...
Posted: Sun Aug 25, 2019 3:07 am
by LTolledo
yup your right on this one...but that doesn't hold charge enough to keep the RPi powered for even 1ms.... :D
Posted: Sun Aug 25, 2019 4:44 am
by W. H. Heydt
Wow! Look at those goal posts go!
Actually, I agree with you. It is a trick answer to a somewhat ambiguous question. The fundamental point being, of course, that there is no energy storage device of any significance on a Pi. No batteries, no large scale capacitors or inductors. Therefore, the proper source of power for a Pi is a "power supply unit" (PSU) and definitely not a device sold as a "charger".
But then...I tend to nitpick the very common but badly used technical terms. To take one that shouldn't be a problem here, there is no such aircraft as an "Me-109". There was a "Bf-109" and an "Me-262", but no "Me-109" in spite of the Bf-109 having been designed by Willy Messerschmidt.
Posted: Sun Aug 25, 2019 7:00 am
by rin67630
The Pi is credit-card sized, but you can't charge anything on it.
SCNR.
:D
Posted: Sun Aug 25, 2019 7:20 am
by fruitoftheloom
Hi everyone,
You need a Power Supply, just buy the Official one:
https://www.raspberrypi.org/products/ra ... er-supply/
Posted: Sun Aug 25, 2019 8:00 am
by matteocamper
Posted: Sun Aug 25, 2019 8:24 am
by drgeoff
ok thanks to all, I'll buy an original power supply;)
To nitpick further, "an original power supply" is not what you should buy.
Posted: Sun Aug 25, 2019 8:49 pm
by pfletch101
My favorite nit is 'geothermal heating', when used for heat pumps which have their outside coils buried under the ground (or in a convenient body of water). Iceland has a significant amount of geothermal heating, and New Zealand has it in a couple of places; I believe that there may also be one or two experimental sites in California. Pretty much everyone else who uses the term just has ground source heat pumps. They work pretty well but they aren't geothermal.
Posted: Sun Aug 25, 2019 8:58 pm
by mahjongg
No you should use the "latest official RPI3 power supply", the one specifically designed for the RP3B+.
the very latest one is for the RPI4, and has an USB-C connector, so not suitable for the RPI3B+
