rin67630
Zero: What is the purpose of the unpopulated connector
Sat Aug 24, 2019 6:48 am
Does someone know, what is the purpose of the unpopulated connector pcb tracks below the camera connector?
FTrevorGowen
Re: Zero: What is the purpose of the unpopulated connector
Sat Aug 24, 2019 8:01 am
By the above do you mean the RUN header and TV (out) connector pins?
(to the right of the "small raspberry logo" see my photo's here: http://www.cpmspectrepi.uk/raspberry_pi ... ersion_1.3)
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
drgeoff
Re: Zero: WhaI t is the purpose of the unpopulated connector
Sat Aug 24, 2019 8:12 am
I expect the OP is referring to the underside of the board. The 8 "fingers" between 2 larger squares. J5 on a Zero v1.2 and v1.3.
rin67630
Sat Aug 24, 2019 8:18 am
I expect the OP is referring to the underside of the board. The 8 "fingers" between 2 larger squares. J5 on a Zero V1.3.
Yes, thank you.
Sat Aug 24, 2019 8:20 am
It's for testing at the production stage.
drgeoff
Sat Aug 24, 2019 8:22 am
Possibly a debug port used during development.
plugwash
Sat Aug 24, 2019 8:23 am
It's the videocore JTAG connector, used for development and test of the firmware and possiblly (not sure on this) for factory programming purposes. Afaict it's of no real use without access to internal broadcom documentation.
Pretty sure the same connector has been used on all Pi models since the B+ (the original A/B use a pin header).
rin67630
Sat Aug 24, 2019 9:19 am
Thank you!
One more thing i have learnt.
