maxdolski
Wifi
Fri Aug 23, 2019 3:48 pm
I tried to connect to a hidden network, but instead , whenever i clicked the WiFi icon, it says no wireless interfaces found. what do i do?
Andyroo
Re: Wifi
Fri Aug 23, 2019 6:24 pm
Have you set the country code up?
Can you post your wpa_supplicant.conf file here please (redact the password)
You should have scan_ssid=1 in the file to allow for hidden SSID networks.
Are you aware hiding the SSID is pointless as it takes seconds extra to find them and they cause more issues for connections and debugging issues?
Paul Hutch
Re: Wifi
Fri Aug 23, 2019 7:54 pm
I think you need to manually edit the configuration file to connect to a network with a hidden SSID. The documentation in the link below has instructions for hidden SSID setup.
https://www.raspberrypi.org/documentati ... ess-cli.md
