XueHai8
PINN - How to create multiple partitions on USB Drive?
Fri Aug 23, 2019 3:03 am
I have a Pi4B and ran Raspbian on it to create multiple partitions on my USB Drive so that I could install and test different OSs.
I then installed PINN on an SD Card and booted it.
But PINN only see's the entire USB Drive, not the individual partitions.
How do I create multiple partitions on the USB driver for multiple OS'es?
Is there documentation or instructions for this somewhere? I can't find any.
The Utility Tab lists multiple 'ProjectSpace' (s) but they all seem to do the same thing and 'Data Partition' only creates a single 512MB partition.
The General Tab only shows 5 options, most being Raspbian.
I can't even figure out how to Shut it Down! The 'Exit' button is greyed out!
I'm missing something.
Any help?
Thanks!
Re: PINN - How to create multiple partitions on USB Drive?
Fri Aug 23, 2019 5:23 am
Any help?
Thanks!
The PiNN developer provides documentation:
https://github.com/procount/pinn/blob/m ... ME_PINN.md
Any queries should be posted in his Post:
https://www.raspberrypi.org/forums/view ... p?t=142574
Retired disgracefully.....
procount
Fri Aug 23, 2019 6:38 am
+1. Thanks Fotl.
PINN manages all the partitioning for you. No need to partition the HDD yourself first. In fact, any existing partitioning will be removed.
