Orange
WiringPi Download (not for Raspbian)
Thu Aug 22, 2019 5:21 am
I'd like to download wiringPi to build on Gentoo but git.drogon.net seems to be permanently down.
I see it's on Github but that page says it's not the official page and I should download it from git.drogon.net
Is it ok to download from the Github page or should I wait and see if Gordon's site comes back online eventually.
Re: WiringPi Download (not for Raspbian)
Thu Aug 22, 2019 5:49 am
https://www.raspberrypi.org/forums/view ... 8#p1517208
Retired disgracefully.....
Thu Aug 22, 2019 9:35 am
Gordon has gone the whole hog and has blocked http://git.drogon.net so you can't pull the official source to hack around with it.
Switch to Joan's pigpio/pigpiod from http://abyz.me.uk/rpi/pigpio/download.html
This is a doctor free zone.
jcyr
Thu Aug 22, 2019 1:39 pm
joan wrote:
Thu Aug 22, 2019 10:33 am
There is also https://www.airspayce.com/mikem/bcm2835/
A good choice. It provides finer grain control, at least for PWM, than either WiringPi or Pigpio does.
It's um...uh...well it's kinda like...and it's got a bit of...
joan
Thu Aug 22, 2019 2:00 pm
Not really. Its hardware PWM is pretty much the same as wiringPi and pigpio and is limited to the 19.2 MHz crystal and 2 channels (pigpio uses a 500 MHz clock). It offers nothing like pigpio's hardware timed PWM on all GPIO.
jcyr
Thu Aug 22, 2019 2:32 pm
Not what I meant with 'finer grain control'. Let's say I want to use true hardware PWM, not fake 'any pin' PWM, and set the clock divider to its max in order to have the lowest possible clock rate driving the PWM block, how would I do this with either pigpio or wiringpi? As far as I can tell, you can't!
I understand that these libs try to make things simple with abstraction, but it's not always helpful.
joan
Thu Aug 22, 2019 2:45 pm
I have not seen a single post requesting the ability to do that. What is the point?
http://abyz.me.uk/rpi/pigpio/pigs.html#HP
hippy
Thu Aug 22, 2019 2:51 pm
It reports "git.drogon.net is temporarily unavailable" for me and Gordon did say "I will make a final release of wiringPi available soon – with the sources, but that’s that. No more public releases" so maybe he is reworking the site to support that. Might be worth trying later or keeping an eye on his site for any updates.
jcyr
Thu Aug 22, 2019 3:00 pm
Well, I guess you've just seen one. I recently needed precisely that for fan speed control.
https://www.raspberrypi.org/forums/view ... 6#p1516346
P.S. I'd love to see pigpio incorporate more direct control, since I think it's already bundled with Raspbian.
Thu Aug 22, 2019 3:06 pm
I found some old versions of wiringPi on github (because folks were breaking Gordon's licensing rules - which is why he's abandoned the project) which look like they're OK but old and unsupportable. (Best was v2.44 which doesn't support RPi3B+.) If you just need the basics search on Github, sort by recently updated and pick the newest version and remember when it breaks you get to keep both pieces.
joan
Thu Aug 22, 2019 3:14 pm
I have version 2.50 of wiringPi on my laptop. There shouldn't be any problem hosting any published version.
joan
Thu Aug 22, 2019 3:18 pm
wiringPi has the same interface as bcm2835 as far as hardware PWM is concerned. They both allow the setting of the clock divider, range, and data settings.
Personally I don't like that model. I have seen dozens of posts asking how to set a particular frequency.
pigpio has a much simpler model. You select a frequency and dutycycle.
jcyr
Thu Aug 22, 2019 3:28 pm
I must have missed something. What function would I call to set the frequency?
jcyr
Thu Aug 22, 2019 4:03 pm
According to the docs, gpioHardwarePWM doesn't support frequencies below 1 MHz. The hardware is capable of frequencies down to about 5 KHz.
joan
Thu Aug 22, 2019 4:29 pm
What docs? You can set a frequency of 1 Hz.
$ pigs hp 18 1 200000
Screenshot from 2019-08-22 17-27-43.png (50.14 KiB) Viewed 812 times
jcyr
Thu Aug 22, 2019 4:56 pm
What docs?
The docs you referred to: C http://abyz.me.uk/rpi/pigpio/cif.html#gpioHardwarePWM
PWMfreq: 1-125M (1-187.5M for the BCM2711)
I interpret that as 1 MHz to 125MHz.
You have set the period to one second, not the PWM input frequency to one hertz. It actually looks like you're setting the input clock of the PWM to 1 MHz and a ON time to 200000 clock tics. Nevertheless, that achieves what I needed. It just isn't very clear what the docs are saying. I naturally opted to do my own calculations and set the PWM input clock divisor and range directly using the bcm2835 lib.
I'll give pigpio a shot. Thanks.
jcyr
Thu Aug 22, 2019 6:46 pm
Hmm... Not quite what I expected! C code:
pi@raspberrypi:~/fanmon $ cat test.c
#include <stdio.h>
#include <pigpiod_if2.h>
#define PWM_GPIO 18u
int main(void)
    int pi = pigpio_start(NULL, NULL);
    // set freq. to 1 Hz
    set_PWM_frequency(pi, PWM_GPIO, 1);
    // display actual freq.
    printf("PWM freq. = %d Hz\n", get_PWM_frequency(pi, PWM_GPIO));
    pigpio_stop(pi);
    return 0;
pi@raspberrypi:~/fanmon $ gcc test.c -lpigpiod_if2 -lrt
pi@raspberrypi:~/fanmon $ ./a.out
PWM freq. = 10 Hz
joan
Thu Aug 22, 2019 7:54 pm
You need to read the documentation for the functions you use.
jcyr
Fri Aug 23, 2019 12:16 am
Ah, ok. hardware_PWM(...) instead of set_PWM_frequency(...)
Had to decipher your source code to figure that out.
davidcoton
Fri Aug 23, 2019 8:06 am
WHY? You quoted the documentation page, and the first heading is...
int gpioHardwarePWM(unsigned gpio, unsigned PWMfreq, unsigned PWMduty)
Did you read what you quoted??? :roll: :o :lol:
Signature retired
jcyr
Fri Aug 23, 2019 1:40 pm
I don't want to be critical, but in hindsight there were a couple of factors contributing to my confusion. First, hardware PWM versus software PWM which are handled very differently. It never occurred to me that anyone would ever want or need anything other than hardware PWM. Odd that hardware PWM is listed as an advanced feature. Second, direct pigpio vs. proxied via the pigpiod daemon. Equivalent functions have different names.
Coming from a silicon design background, calculating clock rates and such is second nature to me. I'm more comfortable specifying things directly rather than having them calculated under the hood for me, hence my initial choice of support library. I don't doubt that the latter is better suited to the targeted audience.
Who actually reads documentation? I generally do that only once I discover my initial assumptions were false! ;)
davidcoton
Fri Aug 23, 2019 8:05 pm
I've learnt to assume that my assumptions are false. :? :lol:
Signature retired
pfletch101
Fri Aug 23, 2019 8:25 pm
I always read through the entire documentation of a hardware device or software package once. I then generally reread the section(s) on whatever I actually plan to use. I find that enough of the complete readthrough generally sticks with me that when something apparently odd (but documented) happens and/or I need a different functionality, it 'rings a bell', and I have a better chance of figuring it out.
Also, I take a lot of trouble documenting the software I write for my clients, and it drives me crazy when I get questions which could be answered by even a cursory reading of the manual.
