drifterf
Large Raspberry Pi Case
Mon Aug 05, 2019 4:35 pm
Hi, hope this is in the right section.
im looking for a case for a pi 3 thats bigger than the normal one, i want to house some of the relay modules etc inside it. i have been just ordering a containment box and building it with pcb stand off etcs. didnt know if anyone knew of a case that has mounts for the pi and space inside for other bits ?
thanks
alphanumeric
Re: Large Raspberry Pi Case
Mon Aug 05, 2019 7:53 pm
I went the same route, large PVC box and mounted the Pi etc on standoffs. Cases for what you build are few and far between. There are tons around for a Pi by itself. And a few special ones for audio hats and PiTFT displays. Other than that though its slim pickings if you add a Hat to your Pi..
drifterf
Tue Aug 06, 2019 5:51 pm
hi mate, thanks i shall continue custom building. might come up with a set design and see if someone can 3d print i suppose, thanks
