jamsab
Control brushless motor speeds
Wed Dec 05, 2012 3:05 pm
Hi everyone, i am completely new to this sort of stuff but im working on an idea but need to work out the components needed before moving forward.
The first thing i need to know is if im on the right track !? i need to take a brushless motor and control / monitor its speeds, similar to as you would a radio controlled car.
Am i right in saying all i need is the Pi, a power supply (AC - DC), the brushless motor ( DC ), and a monitor & video cable ? I guess im missing some bits for controlling the motor am i ??
Any help would be much appreciated.
Jamie
techpaul
Re: Control brushless motor speeds
Wed Dec 05, 2012 3:39 pm
Yes you need externall hardware to drive the brushless motor and something to provide 6 halfs of timing drives. There is not much on the Pi that can directly do it.
You will need power drivers to drive the motor and it is not a five minute job. Motor control is a whole industry sector in itself. I have done things like this before and you need to know the full spec of the motor and its load conditions, including stalled.
Example of timings required for a motor I once worked on
Example of waveforms to drive a brushless motor
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
jamsab
Wed Dec 05, 2012 3:58 pm
Thanks for the info,, i shall get a motor asap and post the specs, just to confirm before i buy the driver,,
im guessing something along these lines ? (depending on motor) :- http://www.pololu.com/catalog/product/755
PeterO
Wed Dec 05, 2012 4:00 pm
jamsab wrote:im guessing something along these lines ? (depending on motor) :- http://www.pololu.com/catalog/product/755
NO ! .... "This discrete MOSFET H-bridge motor driver enables bidirectional control of one high-power DC brushed motor. "
PeterO
Ravenous
Wed Dec 05, 2012 4:03 pm
That controller is for a standard brushed DC motor. Not brushless. Check before you buy!
First, what sort of motor are you going to use?
Second, how accurately regulated do you need the speed to be?
techpaul
Wed Dec 05, 2012 4:08 pm
NO that is for a BRUSHED motor not a BRUSHLESS.
Brushless motors have 4 connections minimum A, B, C and common or something similar
jamsab
Wed Dec 05, 2012 5:08 pm
No worries everyone, :D i wasn't going to buy that particular one, i was just using as an example of type of hardware, like i said im a newbie,, i will get the motor from a model shop i guess,, however i have loads of old PC Fan motors,, would that do ??
Ravenous
Wed Dec 05, 2012 5:11 pm
Actually, I believe the motors in PC fans ARE brushless, not brushed. Are you confused yet? I believe I am :shock:
joan
Wed Dec 05, 2012 5:13 pm
Brushless motors are a new fad. Perhaps you mean the old fashioned motor which is powered by a battery.
jamsab
Wed Dec 05, 2012 5:17 pm
I am, i will soon see the light,, ok i can make do with the PC fan to start with i guess,
DC12V 0.60A BRUSHLESS :)
PeterO
Wed Dec 05, 2012 5:20 pm
It may be worth looking at using an RC model brushless motor controller (Called Electronic Speed Controllers (ESC) by RC modelers) and driving that from the Pi. You would need to create a PWM (Pulse Width Modulation ) signal but there are examples of people doing that already to control RC servo motors.
PeterO
joan
Wed Dec 05, 2012 5:21 pm
Could you provide a link to the specs of the motor?
jamsab
Wed Dec 05, 2012 5:26 pm
Hi Peter, thanks that is exactly what im looking for.
J
alexeames
Wed Dec 05, 2012 5:31 pm
jamsab wrote:Hi Peter, thanks that is exactly what im looking for.
J
You'll find loads of them at giantshark.co.uk or hobbyking.com look for ESC.
The ones made by HobbyWing are a good balance between cost and quality (at least they were last time I bought one a couple of years ago). If quality is paramount, Jeti and Hacker are very good (I think Jeti make the Hacker ones actually).
Alex Eames RasPi.TV, RasP.iO
techpaul
Wed Dec 05, 2012 5:48 pm
joan wrote:Brushless motors are a new fad. Perhaps you mean the old fashioned motor which is powered by a battery.
Such a new fad that most 3.5inch floppy drives have them, nearly every hard drive for last 20 years and various other motoirised items.
garya
Thu Dec 06, 2012 11:10 pm
I second the idea of using an RC electronic speed controller. They work well, are easy to drive with PWM from the raspberry, and are quite inexpensive.
If you only want to drive the motor in one direction, this one can't be beat for the low current you mentioned:
http://www.hobbyking.com/hobbyking/stor ... oduct=4318
cnt
Fri Dec 07, 2012 12:20 am
I think there is a critical question that people are neglecting.
Why do you think you need a brushless motor? Also there are different kinds of brushless motors.
As previously stated there are ones like PC fans which just have two wires (maybe a third for an ecoder). These two wire versions have a simple control circuit in them to generate the AC signal needed.
Generally speaking though, when a person needs a brushless motor they're talking about the 3 terminal (or more) variety like you'd find in RC planes and helecopters.
Honestly, unless you have a good reason for needed a brushless motor I'd use brushed motor with two terminals. They're much easier to deal with, especially when first figuring out how to work with electronics.
mahjongg
Fri Dec 07, 2012 1:19 am
Is this "brushless motor" actually what is normally called a "stepper motor"?
There are many kinds of brushless motor, so its easy to confuse one kind with another.
The only aspect they share is that all of them do not have commutator brushes.
See wikipedia: http://en.wikipedia.org/wiki/Brushless_motor
So first try to read up a bit, so you can accurately describe what you need.
summers
Fri Dec 07, 2012 10:06 am
Well guess you would start by asking how many pole and home many phase is the motor.
Pole tell you how many times you have to switch the current to get the motor to rotate once. Phases is how many signals you have to drive.
Odds are you'll get a 2 phase motor, with some smallish number of poles. Just to show how it works lets say 10 pole for example.
Now the two phases you have to drive in quardature (for a 2 phase motor, for 3 phase - each phase is 120 degrees appart). lets assume you are going for a simple drive, and drive with square waves. Won't be all that smooth - but should get things turning.
So the two quradature signals will look like:
A: 0 0 1 1 and repeating
B: 0 1 1 0 and repeating
Now when you have a 1, you want to drive current through that winding in one direction, and when you have a zero you want to drive in the reverse direction. So you'll need to set up the external electronics for doing that. Thing to look at is a H bridge.
Now for a 10 pole motor you will need to send out the signal above 10 times to get the motor to rotate once - so you can use that to work out how fast to turn.
Next onto comutation. This is about how fast do you switch through the above waveforms. With any luck your motor will have hall sensors or something, that tells you when the motor has turned enough for the waveform, to move on. if you got that it would be worth monitoring.
So I guess thats the basics, typical motor drives are a fair bit more complex ...
