Raspberry Pi 4 and overscan
Posted: Wed Jul 24, 2019 5:10 pm
by tyche101
I cannot get the overscan to work on my Raspberry Pi 4. The screen does not fit on the TV that I'm using. I did not have this issue with my Raspberry Pi 2b. Here is what I have in my config.txt on the Raspberry Pi 4
# uncomment this if your display has a black border of unused pixels visible
disable_overscan=0
overscan_left=40
overscan_right=40
overscan_top=40
overscan_bottom=40
# overscan.
framebuffer_width=1280
framebuffer_height=800
Any ideas? Thanks
Re: Raspberry Pi 4 and overscan
Posted: Wed Jul 24, 2019 7:31 pm
by jamesh
Did you do a search of the forum first? Because this has been covered a LOT of times. Right now, no, overscan hasn't been implemented, but it should be fairly soon.
Posted: Sat Sep 07, 2019 12:44 pm
by m4r35n357
Well mine is still unusable. Can anyone here quantify "fairly soon"?
Posted: Sat Sep 07, 2019 1:17 pm
by FTrevorGowen
Perhaps you've missed this thread: https://www.raspberrypi.org/forums/view ... 3&t=250675 ?
Trev.
Posted: Sun Sep 08, 2019 4:54 pm
by Atari2020
If you have overscan on your monitor try commenting out the line for the new video driver in config. I am on my Pi 3 right now and I do not have it. I think it is the last line, or two lines I comment out on the Pi 4 and it solved my overscan problem. It took it back to the Pi 3 driver. Maybe this will help.
