base0
cannot build tensorflow from source
Fri Jul 19, 2019 2:47 pm
I am using Raspberry Pi 3 B+. The operating system is Raspbian 10. I installed docker and follow the instruction for building tensorflow from source https://www.tensorflow.org/install/source_rpi
git clone https://github.com/tensorflow/tensorflow.git
cd tensorflow
git checkout r1.9
CI_DOCKER_EXTRA_PARAMS="-e CI_BUILD_PYTHON=python3 -e CROSSTOOL_PYTHON_INCLUDE_PATH=/usr/include/python3.4" \
    tensorflow/tools/ci_build/ci_build.sh PI-PYTHON3 \
    tensorflow/tools/ci_build/pi/build_raspberry_pi.sh
I got the following error.
Package ffmpeg is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ffmpeg' has no installation candidate
The command '/bin/sh -c /install/install_deb_packages.sh' returned a non-zero code: 100
ERROR: docker build failed. Dockerfile is at /home/pi/tensorflow/tensorflow/tools/ci_build/Dockerfile.pi-python3
Re: cannot build tensorflow from source
Fri Jul 19, 2019 3:33 pm
It should be noted that ffmpeg is available in the current Raspbian build, but as the compilation is taking place inside a Docker container it might be worth creating an issue on the tensorflow github page.
I see they say they support all Pi models up to Pi 3 and Raspbian "9 and above" but I'm not sure if they've been able to test it with Buster (10) yet..
base0
Fri Jul 19, 2019 11:21 pm
Thank you. I posted the issue in TensorFlow github. https://github.com/tensorflow/tensorflow/issues/30891
