hippy
[SOLVED] Buster 'apt-get update' issue
Mon Jul 08, 2019 2:16 pm
pi@Pi3B:~ $ sudo apt-get update
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Get:3 http://archive.raspberrypi.org/debian buster/main armhf Packages [205 kB]
Reading package lists... Done
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Nothing in 'man apt-secure' seemed to tell me what to do - So what exactly do I have to do to make things work ?
trejan
Re: Buster 'apt-get update' issue
Mon Jul 08, 2019 2:28 pm
Debian Buster was released so it changed to stable.
Run "sudo apt update --allow-releaseinfo-change" and it'll update it.
MrEngman
Mon Jul 08, 2019 2:29 pm
hippy
Re: [SOLVED] Buster 'apt-get update' issue
Mon Jul 08, 2019 2:59 pm
Thanks. "sudo apt-get update --allow-releaseinfo-change" fixed it for me.
I hadn't seen an Unread Post mentioning it, and a search found nothing obvious. I guess Sod's Law, or Search Fu Failure, given searching now finds a number of threads referencing the issue.
uilfut
Mon Jul 08, 2019 7:44 pm
I was stuck too, and found the answer here - so thanks for asking!
Dan1jel
Contact: Twitter
Tue Jul 09, 2019 9:10 pm
I too had problem with this and was stuck. Thank you for the solution. And thank you OP for starting this thread.
hardwaremack-orginal
Tue Jul 09, 2019 9:20 pm
would of been nice if inside the app it would have said something like type * sudo apt update * if you would like to continue. Thank goodness for this forum.
ibshar
Thu Jul 11, 2019 3:38 pm
Thank You
Juanca
Fri Jul 26, 2019 8:21 pm
Hi!
Thanks Trejan for your answer :!:
Rgrds
Ireneos
Wed Jul 31, 2019 2:31 pm
Thanks. Resolved it on pi 4 (that had new noobs card!)
