cpnetserver
RaspBerryPi 4 - OMXPlayer not work
Sun Jul 07, 2019 6:17 pm
Hi guys!
New PI, same old problem...
I'm trying to watch videos with omxplayer but not work, this is the error that gives me back:
root@RaspBPi4:/home/pi # omxplayer mr_robot_1x1.mkv
Chapter : 0 00:00:00.000 0.00
Chapter : 1 00:06:35.562 395.00
Chapter : 2 00:31:28.637 1888.00
Chapter : 3 00:43:58.845 2638.00
Video codec omx-h264 width 1920 height 1080 profile 100 fps 23.976025
Audio codec ac3 channels 2 samplerate 48000 bitspersample 16
Subtitle count: 3, state: off, index: 1, delay: 0
* failed to add service - already in use?
V:PortSettingsChanged: 1920x1080@23.98 interlace:0 deinterlace:0 anaglyph:0 par:0.90 display:0 layer:0 alpha:255 aspectMode:0
/usr/bin/omxplayer: line 67: 2782 Aborted LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
Can someone help me?
Thanks for reply.
6by9
Re: RaspBerryPi 4 - OMXPlayer not work
Sun Jul 07, 2019 6:36 pm
The subtitle and on screen display of omxplayer use the openvg library which is only present on the older Pi models. The on screen display has been disabled for pi4, but it sounds like subtitles still try to render using it. I haven't got a Pi to hand to check, but there should be an option to disabled the subtitles, and that should then work.
cpnetserver
Sun Jul 07, 2019 6:40 pm
I transformed the mkv video into mp4 and now work rightly.
Thank You very much...! ;)
cjan
Sun Jul 07, 2019 9:44 pm
same here, omxplayer can not player anything in buster, Rpi2b.
gkreidl
Sun Jul 07, 2019 9:55 pm
Are you using the legacy driver or one of the KMS drivers?
Minimal Kiosk Browser (kweb)
cjan
Sun Jul 07, 2019 10:12 pm
buster default FKMS.
6by9
Mon Jul 08, 2019 6:33 am
Pi 0-3 should be identical. You'll need to provide any error logs if you want help.
And the default for pi 0-3 is still the legacy driver, not fkms.
Fidelius
Mon Jul 08, 2019 7:10 am
Omxplayer won't run on Raspbian 10-Buster when you use the fkms or kms driver, i.e. when your /boot/config.txt file has in it this line:
dtoverlay=vc4-fkms-v3d
or
dtoverlay=vc4-kms-v3d
Remove it and omxplayer works again.
VLC is running nicely on the Pi with HW acceleration in window and fullscreen mode, and is also compatible with an enabled (f)ksm driver.
6by9
Mon Jul 08, 2019 11:16 am
or
It should, but there's a minor bug in detecting the fkms or kms overlay. I've raised an issue - https://github.com/popcornmix/omxplayer/issues/720
Add "--no-osd" to the command line and it'll run fine.
Fidelius
Mon Jul 08, 2019 11:20 am
Ah, this explains it.
Thanks for the "--no-osd" info and for the bug-report!
piSignage
Mon Jul 22, 2019 6:01 am
Thanks for the bug report and the flag!
