Aardappeltaart
RPI4, out of order and Spectre vulnerabilities
Sun Jun 30, 2019 12:01 pm
I always consider this post by Eben as one of the most informative and best educational posts about modern CPU and (potential) security issues.
But now the RPI4 has out-of-order A72 cores, which have Speculative Processor Vulnerabilities (17/Jun/2019)
Processor   Variant 1  Variant 2 Variant 3 Variant 3a Variant 4
Cortex-A72     Yes         Yes**     No**     Yes**        Yes
I do wonder if the Pi cores have hardware mitigations, mentioned in the linked page
However, an update for the latest release of the Cortex-A72 does include a hardware mitigation for this issue.
And what about software mitigations? On my Intel Ubuntu 1804 laptop:
ls -1A /sys/devices/system/cpu/vulnerabilities
l1tf
mds
meltdown
spec_store_bypass
spectre_v1
spectre_v2
cat /sys/devices/system/cpu/vulnerabilities/*
Mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Mitigation: Clear CPU buffers; SMT vulnerable
Mitigation: PTI
Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Mitigation: __user pointer sanitization
Mitigation: Full generic retpoline, IBRS_FW, STIBP: conditional, RSB filling
RPI4
'/sys/devices/system/cpu/vulnerabilities/*': No such file or directory
Does that mean there are no vulnerabilities in the RPI4 cores, or that there are no mitigations in place, or that info is simply missing at the moment?
Re: RPI4, out of order and Spectre vulnerabilities
Sun Jun 30, 2019 12:09 pm
l1tf
mds
meltdown
spec_store_bypass
spectre_v1
spectre_v2
Mitigation: PTI
RPI4
https://www.raspberrypi.org/forums/view ... 3&t=243594
Retired disgracefully.....
Sun Jun 30, 2019 2:58 pm
Whilst these are technically vulnerabilities, have any of these been detected in actual malware? It's always seemed ferociously difficult to actually move from proof of principle to actually being able to compromise a system.
Sun Jun 30, 2019 3:34 pm
Quite right James. There are a million other ways bad guys can get data out of you that do work and are used in the wild. Just check the news everyday of this or that new vulnerability being found or this or that site/service being infiltrated..
Whilst one is busy worrying about all of those, or better still keeping up with the news and taking precautions appropriately, Specter and Meltdown are very low on the list of security concerns.
echmain
Sun Jun 30, 2019 3:56 pm
Specter and Meltdown became extremely well known simply because their names invoke frightening images. Like something out of a Bond movie.
The pop media outlets caught on and ran with it.
Never let the facts get in the way of a good story.
jdb
Sun Jun 30, 2019 4:08 pm
A72 is immune to Meltdown. A72 is vulnerable to Spectre, but this means context leakage in the same process space.
The practical upshot of this is that on A72, there is yet another way to exfiltrate data from the web browser via malicious javascript - that is mitigated against quite effectively via a) site/process isolation - each tab gets its own process cluster and b) recompiling with "CDSB" speculation barriers and retpolines enabled at critical points. Do both of these, and Spectre is relegated to an academic curiosity on Pi 4.
Rockets are loud.
https://astro-pi.org
lb
Sun Jun 30, 2019 5:17 pm
I guess the question is: is Raspbian Buster compiled with tne necessary mitigations? And again, the question remains if the A72 cores have some of the hardware mitigations in place. These vulnerabilities are a significant issue if that isn't the case.
Sun Jun 30, 2019 5:32 pm
No, IMO they are not a significant issue, even if the mitigation isn't built in to the kernel or the silicon. because, as above, AIUI there is no malware that uses this attack vector.
Aardappeltaart
Sun Jun 30, 2019 6:24 pm
On my AMD Ubuntu 18.04:
Not affected
Not affected
Not affected
Not affected
Mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
As you can see, Meltdown is only an issue on Intel, and Ubuntu is nicely reporting that. compare it with OP.
AMD ubuntu 1804
dmesg | grep retpoline
[    0.028872] Spectre V2 : Mitigation: Full AMD retpoline
RPI4
No output, so no retpoline mitigation in Raspbian Buster (reported).
I doubt you could write this off as an academic curiosity or harmless because `there is no malware that uses this attack vector.`.
ARM tells a different story (17-06-2019),see link OP, they explicitly state that an A72 processor is vulnerable, and write about needed mitigation mechanisms.
jdb
Sun Jun 30, 2019 10:54 pm
Re-read my post. I didn't state that it's currently an academic curiosity on A72 - only when mitigations are applied.
Rockets are loud.
chwe
Mon Jul 01, 2019 12:09 am
Then this should be default? shouldn't it? is it?
lb
Mon Jul 01, 2019 1:16 am
Sorry, but that's a really bad argument. With this kind of reasoning, you might as well never pro-actively fix any security bugs - until your systems are compromised. If the CPU cores are affected by significant Spectre variants, mitigations must be applied. I'm not sure why this is even being discussed!
Cortex-A72 is affected by four different Spectre variants. We need some clarity about what hardware mitigations are enabled in the core revision used (if any) and what mitigations are in place in kernel and Raspbian userland.
Mon Jul 01, 2019 5:02 am
lb,
Normally I would wholeheartedly agree with you.
If we were discussing a "normal" software vulnerability. They are usually simple bugs in some code somewhere. Or some oversight in their logical design. They can be relatively easily fixed with a patch to the appropriate software item(s)
Specter and Meltdown are rather different. There is no logical bug in the processor hardware or in the Linux kernel or in the application software. Nothing that one can point a finger at and can be easily patched.
Those that research this and have been commenting on it say it's very hard to defend against, and requires work that permeates everything.
And that they expect an endless stream of further demonstrations of different styles of exploiting it over the coming years.
For example, read what Linus Torvalds has said about it recently https://devops.com/linus-torvalds-sees- ... hes-ahead/
lb
Mon Jul 01, 2019 7:10 am
I don't agree: side-channel attacks are nothing new. What's new is that the bugs are on the hardware level and tricky to fix. However, it is, without significant exceptions, the consensus among OS vendors and CPU manufacturers, that the Spectre bugs are serious and have to be mitigated by default. It is irresponsible to ignore that.
Aardappeltaart
Mon Jul 01, 2019 8:18 am
I did read it. That is why I did a grep on retpoline.
You sounded like if you do a and b (including retpoline) then it is practically solved.
I doubt that, mitigations are mitigations, not fixes.
Furthermore retpoline is not gonna help on ARM according to ARM
Arm has investigated the use of retpoline and has concluded that it doesn't provide effective mitigation on Arm-based systems.
And as the Pi is developed for educational purposes, it does sound like the right computer for academic curiosities, making it even more relevant.
Mon Jul 01, 2019 8:32 am
Fixes for Fixes/Meltdown require silicon modification, and that I believe impacts heavily on performance. So SW mitigations are what we have available. And those also have a major performance implication.
I suggest that if you are unhappy with the Pi4 and its use of the A72, and are concerned with possible malware that exploits this, then you use earlier models which do not have this issue.
Meanwhile, I'm going to keep using the Pi4 until someone can point me the in the direction of actual malware on the Pi that takes advantage of the vulnerability and can ACTUALLY do bad things. Note, this is my personal opinion and in no way reflects the opinion of Raspberry Pi, which may be different. I do not know what the official stand is on this.
Mon Jul 01, 2019 9:17 am
lb,
True. Side-channel attacks, "covert channels" as GCHQ likes to call them, have been around forver and still are.
A classic example is the fact that one could snoop on the RF emissions of computers monitors and harvest all kinds of information, even when not in the building! For this reason my office when working on sensitive military projects had no windows, no telephone lines or network connections, and had to be located quite some way inside the perimeter fence of the site.
Did anyone ever fix that side channel in monitors? No. Did any one care? Not so many. Did it ever get used as an exploit for real? Probably on some rare occasions.
Point is, it was not a bug in hardware or software. It could not be fixed easily or cheaply. If it was an issue to you then you took your own precautions.
I view Specter and Meltdown in the same light as that remote monitor sniffing. It's not a bug. It's is hard to eliminate. It does not affect anybody yet. It is only a concern if you are running unknown, untrusted code on your machines. For example if you are a cloud hosting service running all kind of code for clients in VMs. Or if you are in the habit of downloading and running all kind of unknown code to your PC, from random web sites.
Also, similarly to the monitor snooping side channel, if it is a concern for you then take responsibility:
1) In the extreme don't use machines that are susceptible to it. Use older Pi for example. Or very old PC's.
2) Don't keep sensitive information on your Pi. Or any PC for that matter.
3) Don't download and run all kind of unknown and untrusted code from God knows where.
4) Disable JS in your browsers and such.
I don't want to imply that Specter and Meltdown are not serious and can be ignored. Far from it.
Not only is it a "consensus among OS vendors and CPU manufacturers" that this is a problem. They are also working very hard to do something about it. That's a lot of people from the chip makers, to the kernel developers, to browser creators and all kind of other things.
Expecting the Pi Foundation to just "Fix it" is as unreasonable as it would have been to expect PC builders to fix the monitor RF emissions side channel back in the day.
In short, take responsibility of your own security. Be aware. Take counter measures in proportion to the threat and the importance of what you are protecting.
LeMoog
Mon Jul 01, 2019 11:29 am
Indeed do not poopoo securities vulnerabilities unless of course you are willing to help pay to mitigate the damage done when they are exploited.
I really liked the idea of a desktop replacement PI but for me it would be to replace the known security fail that is the x86.
With a vulnerable PI with it's single hardware base then it is going to be hit harder than even the x86 especially with the emphasis upon IOT and other always on services.
6by9
Mon Jul 01, 2019 11:47 am
/sys/devices/system/cpu/vulnerabilities/ is provided by the kernel config option CONFIG_GENERIC_CPU_VULNERABILITIES.
It is not a user configurable option, and is set automagically for alpha, powerpc, x390, and x86 platforms only. (Why it is not set for ARM is a question for the ARM maintainers, but is not in itself an issue)
The main config option for Spectre mitigation on ARM is CONFIG_CPU_SPECTRE, which then selects CONFIG_HARDEN_BRANCH_PREDICTOR and others. This is enabled on the Pi4 kernel build I've just checked.
pi@raspberrypi:~ $ zcat /proc/config.gz | grep SPECTRE
CONFIG_CPU_SPECTRE=y
The arm64 architecture appears not to have any config options directly referencing Spectre.
retpoline is a phrase coined within the x86 architecture
~/Pi/linux/arch$ grep -R retpoline *
x86/Makefile:  # are subject to retpolines for small number of switch cases.
x86/Makefile:  # retpoline builds, however, gcc does not for x86. This has
x86/Makefile:	@echo "You are building kernel with non-retpoline compiler." >&2
x86/include/asm/nospec-branch.h: * This is required in various cases for retpoline and IBRS-based
x86/include/asm/nospec-branch.h: * This should be used immediately before a retpoline alternative.  It tells
x86/include/asm/nospec-branch.h: * objtool where the retpolines are so that it can make sense of the control
x86/include/asm/nospec-branch.h: * objtool the subsequent indirect jump/call is vouched safe for retpoline
x86/include/asm/nospec-branch.h:	.pushsection .discard.retpoline_safe
x86/include/asm/nospec-branch.h: * These are the bare retpoline primitives for indirect jmp and call.
x86/include/asm/nospec-branch.h:.Ldo_retpoline_jmp_\@:
x86/include/asm/nospec-branch.h:	call	.Ldo_retpoline_jmp_\@
x86/include/asm/nospec-branch.h:	".pushsection .discard.retpoline_safe\n\t"		\
x86/include/asm/nospec-branch.h: * For i386 we use the original ret-equivalent retpoline, because
x86/include/asm/nospec-branch.h:#else /* No retpoline for C / inline asm */
x86/include/asm/nospec-branch.h: * retpoline and IBRS mitigations for Spectre v2 need this; only on future
x86/include/asm/nospec-branch.h: * With retpoline, we must use IBRS to restrict branch prediction
x86/include/asm/nospec-branch.h: * With retpolines configured:
x86/include/asm/nospec-branch.h: * Without retpolines configured:
x86/kernel/cpu/bugs.c:bool retpoline_module_ok(bool has_retpoline)
x86/kernel/cpu/bugs.c:	if (spectre_v2_enabled == SPECTRE_V2_NONE || has_retpoline)
x86/kernel/cpu/bugs.c:	[SPECTRE_V2_RETPOLINE_GENERIC]		= "Mitigation: Full generic retpoline",
x86/kernel/cpu/bugs.c:	[SPECTRE_V2_RETPOLINE_AMD]		= "Mitigation: Full AMD retpoline",
x86/kernel/cpu/bugs.c:	{ "retpoline",		SPECTRE_V2_CMD_RETPOLINE,	  false },
x86/kernel/cpu/bugs.c:	{ "retpoline,amd",	SPECTRE_V2_CMD_RETPOLINE_AMD,	  false },
x86/kernel/cpu/bugs.c:	{ "retpoline,generic",	SPECTRE_V2_CMD_RETPOLINE_GENERIC, false },
x86/kernel/cpu/bugs.c:		pr_err("retpoline,amd selected but CPU is not AMD. Switching to AUTO select\n");
x86/kernel/cpu/bugs.c:			goto retpoline_auto;
x86/kernel/cpu/bugs.c:			goto retpoline_amd;
x86/kernel/cpu/bugs.c:			goto retpoline_generic;
x86/kernel/cpu/bugs.c:	pr_err("Spectre mitigation: kernel not compiled with retpoline; no mitigation available!");
x86/kernel/cpu/bugs.c:retpoline_auto:
x86/kernel/cpu/bugs.c:	retpoline_amd:
x86/kernel/cpu/bugs.c:			pr_err("Spectre mitigation: LFENCE not serializing, switching to generic retpoline\n");
x86/kernel/cpu/bugs.c:	retpoline_generic:
x86/kernel/cpu/bugs.c:	 * the user might select retpoline on the kernel command line and if
x86/lib/Makefile:lib-$(CONFIG_RETPOLINE) += retpoline.o
x86/Kconfig:	  Compile kernel with the retpoline compiler options to guard against
Don't take it as a golden phrase that applies to everything.
Basically the main mitigations within the kernel are in place.
Mon Jul 01, 2019 12:45 pm
LeMoog,
Nonsense.
Firstly are you suggesting that that x86 systems used by MS, Google, Amazon and most other cloud service providers aren't allways on? It's news to me that they turned them off at night :)
Anyone building IoT boxes should not be running any code random code of unkown origin that the device thinks is a good idea to download and run. If it is then there are bigger more easily exploited vulnerabilities in store for it.
Despite the amazing sales of the Pi it's still a drop in the ocean compared to x86 for PCs, laptops, servers. It's a drop in the ocean compared to all the other IoT systems out there.
If you want to forgo the Pi and stay with your far more insecure PC then go ahead.
Mon Jul 01, 2019 1:17 pm
You may need to `sudo modprobe configs` to get the proc entry.
I wonder if turning this off will improve performance?
bensimmo
Mon Jul 01, 2019 1:30 pm
LeMoog,
Nonsense.
It's a drop in the ocean compared to these portable computer things I'm holding in my hand typing this on.
Which I believe is Linux right at the bottom of it all.
I'm assuming there are a couple of them around, and some powerful one must use the same processor, lucky for me mine only has 8 of the lowly A53
Aardappeltaart
Mon Jul 01, 2019 2:41 pm
Thx 6by9. That is useful info.
Interestingly mitigations are also in place at my RPI2, which is not vulnerable at all.
pi@pi2:~ $ zcat /proc/config.gz | grep SPECTRE
Which makes jamesh question relevant:
Will turning this off improve performance?
6by9
Mon Jul 01, 2019 4:06 pm
Support for the mitigations is built in.
My recollection of all the x86 mitigations is that they can all be disabled from the Linux command line, so I wouldn't be surprised if they were automatically disabled should the processor not need them. I'm not going to investigate them further.
Aardappeltaart
Mon Jul 01, 2019 5:25 pm
Yes, I think you're right. In Linux (>5.2) it's something like adding to grub ` mitigations=off ` or `pti=off spectre_v2=off l1tf=off nospec_store_bypass_disable` on older kernels, while the default is `mitigations=auto`, so I guess adding that to `/boot/cmdline.txt` might work.
I was just surprised to see it enabled in Stretch, but `auto` does make sense.
