Page 2 of 2
Re: Kodi is broken on raspbian buster
Posted: Mon Sep 02, 2019 9:31 pm
by Rascas
r1ckdu wrote: ↑Mon Sep 02, 2019 5:19 pm
Trying to install kodi from the pipplware repository i get the following error:
apt install kodi
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kodi : Depends: kodi-bin (>= 2:18.3-2~buster) but 2:17.6+dfsg1-4+b1 is to be installed
Depends: libshairplay0 but it is not installable
E: Unable to correct problems, you have held broken packages.
The output of
however shows:
kodi:
Installed: (none)
Candidate: 2:18.3-2~buster
Version table:
2:18.3-2~buster 500
500 http://pipplware.pplware.pt/pipplware/dists/buster/main/binary Packages
100 /var/lib/dpkg/status
2:18.3-1~buster 500
2:17.6+dfsg1-4+b1 500
500 http://httpredir.debian.org/debian buster/main arm64 Packages
What now?
Did you run "sudo apt update && sudo apt dist-upgrade" first ?
Posted: Sun Sep 08, 2019 4:23 pm
by sdpgo12
What file do I need to edit so that when I do a SUDO APT-GET UPDATE/UPGRADE, I will get Raspbian STRETCH? I plan to install kodi LEIA, then move back to BUSTER. Will this work and how do I keep kodi from updating after the install?
Posted: Sun Sep 08, 2019 5:58 pm
by amilino
sdpgo12 wrote: ↑Sun Sep 08, 2019 4:23 pm
You don't need to do that and it will not probably work.
Please read first post here
https://www.raspberrypi.org/forums/view ... 8&t=246837
Posted: Sun Sep 08, 2019 9:28 pm
by virii
The packages for stretch are incompatible with buster. It's the whole reasoning for using the pipplware repository I mentioned on page one.
I'm running Leia 14.2 on buster as we speak on my 3B+
Posted: Wed Sep 18, 2019 8:28 pm
by arv2906
unable to install kodi after pipplware repositories
sudo apt install kodi
kodi : Depends: kodi-bin (>= 2:18.4-3~buster) but it is not going to be installed
Depends: kodi-bin (< 2:18.4-3~buster.1~) but it is not going to be installed
Depends: python-bluez but it is not installable or
python-lightblue but it is not installable
Depends: libshairplay0 but it is not going to be installed
Depends: libaacs0 but it is not installable
Depends: libcec4 but it is not going to be installed
Recommends: libva-intel-vaapi-driver but it is not installable
Recommends: libva1 but it is not installable
I did sudo apt update && sudo apt dist-upgrade
Posted: Thu Sep 19, 2019 12:47 am
by virii
Uninstall Kodi and it's dependencies then reinstall
Posted: Thu Sep 19, 2019 9:03 am
by LTolledo
did you follow the steps outlined in the link below?
https://www.raspberrypi.org/forums/view ... 6&t=251645
if not then there is no guarantee that your setup will work
if you dont/never want to follow the steps it up to you.
I followed the steps....and my Kodi installation worked!
