scales11
PiZeroW i2c microphone Stretch Issue
Thu Jun 20, 2019 2:21 pm
Hello all.
I am trying to get an i2c microphone working on my raspberry pi zero. The module and tutorial are from Adafruit:
https://learn.adafruit.com/adafruit-i2s ... g-and-test
but I can only get it working on Debian Jessie.
I think the kernel compiles ok when I run "rpi-source --skip-gcc"...it asked me a few questions (none of which I was smart enough to write down) and now it says it's already loaded so I don't think I can re-run it without a fresh install. The trouble I am having is that when I try and compiles PaulCesars i2c module, I get:
pi@raspberrypi:~/rpi-i2s-audio $ make -C /lib/modules/$(uname -r )/build M=$(pwd) modules
make: Entering directory '/home/pi/linux-2f8d963db206ce596f9a9e951ec425e9c3e1b4d9'
  Building modules, stage 2.
  MODPOST 1 modules
WARNING: "__sanitizer_cov_trace_pc" [/home/pi/rpi-i2s-audio/my_loader.ko] undefined!
make: Leaving directory '/home/pi/linux-2f8d963db206ce596f9a9e951ec425e9c3e1b4d9'
pi@raspberrypi:~/rpi-i2s-audio $ sudo insmod my_loader.ko          insmod: ERROR: could not insert module my_loader.ko: Unknown symbol in module
Maybe it's not compatible with Stretch?
Can anyone offer advice on how to use this microphone with Debian Stretch?
scales11
Re: PiZeroW i2c microphone Stretch Issue
Thu Jun 27, 2019 5:18 pm
Any help?
gregeric
Thu Jun 27, 2019 6:14 pm
You could try: https://www.raspberrypi.org/forums/view ... p?t=173640
Or, more simply, enable eg the Google Voice HAT overlay, which similarly contains i2s mems microphones. There may be other overlays which work; possibly a typo but it's an i2s (fast digital audio), not i2c (slow serial open collector) mems mic you have.
