aleksejevs64
Raspberry pi 3 ETHERCat
Fri May 31, 2019 9:46 am
Hello everyone!
Is it possible to reconfigure standard Pi Ethernet port to EtherCat, or it necessary use special EtherCat module for it?
If it possible, how?
Thank you!
Re: Raspberry pi 3 ETHERCat
Fri May 31, 2019 10:00 am
Had a quick read of this https://en.wikipedia.org/wiki/EtherCAT, and the answer to your question I think is no, you cannot use the on board ethernet, you would need a specific Ethercat device, most likely USB connected.
food
Sat Jun 22, 2019 12:22 pm
I am not an expert on the subject but I have dealt with EtherCAT for industrial controllers and have vague plans to one day using it with a Raspberry Pi. As far as I am aware, EtherCAT masters use standard Ethernet hardware.
That said, the main benefit of EtherCAT is it's speed for realtime systems. Safety, motion control, etc. As Jamesh mentioned, I don't think Raspberry Pi can take advantage of that by itself and you would need extra hardware.
I have not looked over the whole site , but there is some interesting stuff over here:
http://www.simplerobot.net/2018/06/rpi- ... picat.html
I believe they are only using extra hardware for the realtime portion of EtherCAT.
If you want to make a non-realtime master then look at SOEM (Simple Open EtherCAT Master):
https://openethercatsociety.github.io/
If you want to make a slave you will definitely need specialized hardware.
Again, not an expert. Maybe there is some helpful information here.
ranpitime
Mon Sep 23, 2019 7:12 pm
Ethercat Master is possible on the eth0 without any additional hardware - even with distributed clocks - then a rt_preempt patch is needed.
https://store.codesys.com/codesys-contr ... pi-sl.html
or
https://store.codesys.com/codesys-contr ... mc-sl.html
the multicore version of the CODESYS runtime/plc. ( difference is - you could specify what should run on which cpu core)
Etrhercat Slave - no additional hardware is needed.
BR
Edwin
