sushant_ocv
Unable to Access the Pi over SSH
Tue May 28, 2019 10:19 am
Have you seen this before.
Re: Unable to Access the Pi over SSH
Tue May 28, 2019 10:33 am
More details required please.
Which Pi?
What OS is installed?
Did you activate ssh?
What system are you trying to connect from and how?
What error messages (if any) are you getting?
LTolledo
Tue May 28, 2019 11:51 am
sushant_ocv wrote:Have you seen this before.
What about it?
you planning to add more details?
or you prefer us to guess?
but definitely you cannot access it (whatever it is) if it is NOT powered...has no Operating System, and no network connection of sort....
Some people be like:
pcmanbob
Tue May 28, 2019 12:54 pm
Yes often the result of the user not setting things up correctly.
as others have said please provide more information.
You should also read the SSH documentation https://www.raspberrypi.org/documentati ... /README.md
luckydog
Wed Jun 05, 2019 8:46 am
90% of the time I have had this problem it was because I was a little rushed or distracted and completely forgot to add the ssh file onto the card after disk imaging-DOH
The other time was that I had not put the right image version on for my pi, hadn't powered up (yes I know!) and using images with user and password that are not standard raspberry ones.
Double check hardware setup, double check software then research helps :0)
