charaf
Installing an .exe file on raspberry pi 3 b
Tue Mar 12, 2019 4:34 pm
Hello, im searching for a way to install an exe file on my raspberry pi even when i tried some solutions like playonlinux i faced problems with wine
i really need a solution :cry:
thank you for help.
Re: Installing an .exe file on raspberry pi 3 b
Tue Mar 12, 2019 4:49 pm
Wine is the obvious choice, but you would then need to run it un QEMU to emulate the x86 processor. Probably other options, but all a bit complicated.
If that doesn't work, I doubt there is much chance of getting it working.
What does the exe do? There may be a Linux equivilent you can use instead.
charaf
Wed Mar 20, 2019 8:53 pm
hello SIR , i have tried to run the application(.exe) witch turns on the connection of a 3g dongle on linux , hoping to find solution for connecting my huawei e3372h-153 3g dongle after i tried sakis3g and also tried to change the mode of my dongle from stick to hilink but also a didn't get it.
I really facing a huge problem in connecting my 3g dongle in raspberry pi !
any idea you got could help me !
thanks
Roken
Wed Mar 20, 2019 9:04 pm
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
pfletch101
Wed Mar 20, 2019 9:11 pm
Since what you are apparently trying to install is presumably some sort of device driver, I would estimate your chances of success in installing the Windows software on a PI (or any Linux machine) as 'slim to none'. You need to find Linux drivers for it. The link that Roken has posted may help you, though your specific modem is not on the 'supported' list there.
