Page 1 of 3
Is there a cheap and reliable UPS for raspberry pi 3b+?
Posted: Fri Mar 08, 2019 8:13 am
by crocket
I don't want to buy a full-fledged UPS that costs more than 100 USD.
It seems most USB power banks are unsuitable as UPS. Plus, they don't report power levels or whether mains power is available.
Is there a cheap and reliable UPS for raspberry pi 3b+? I want one that doesn't shut down raspberry pi as soon as power goes out.
Re: Is there a cheap and reliable UPS for raspberry pi 3b+?
Posted: Fri Mar 08, 2019 8:26 am
by fruitoftheloom
https://www.modmypi.com/raspberry-pi/po ... 1/ups-pico
https://www.modmypi.com/raspberry-pi/po ... ontrol-hat
Posted: Fri Mar 08, 2019 8:32 am
by B.Goode
Not a recommendation, but just pointing out a product. And yes, I can see it is marked Out of Stock.
https://uk.pi-supply.com/products/pijuice-standard
Posted: Fri Mar 08, 2019 9:20 am
by crocket
Posted: Fri Mar 08, 2019 9:26 am
by rpiMike
Try searching for a power bank with ‘pass through’ charging. Supposedly they work like a UPS.
Posted: Fri Mar 08, 2019 9:38 am
by crocket
Do those pass-through power banks charge as fast as Raspberry Pi draws power from it?
Posted: Fri Mar 08, 2019 10:15 am
by B.Goode
Are there cheaper ones?
With reference to your parallel thread which puts some parameters on your requirement.
You are unlikely to find something both cheap and reliable that gives you autonomous operation for some hours.
My impression is that the 'cheap and cheerful' options are intended to give you a few minutes of run time so that you can perform a clean shutdown under controlled circumstances.
Posted: Fri Mar 08, 2019 10:20 am
by Imperf3kt
Do you have a soldering iron and know how to use it?
Posted: Fri Mar 08, 2019 11:04 am
by crocket
I guess I don't want to keep replacing batteries once every 2~4 years.
I want something like https://juice4halt.com/ which is less than half as expensive as juice4halt.
Imperf3kt wrote: Do you have a soldering iron and know how to use it?
I learned how to use a soldering iron by watching videos. I really wanted to make a custom keyboard with a soldering iron. But, I haven't bought and used one because I didn't like inhaling solder fume which is harmful. Plus, the ventilation system was bulky and added more cost to the soldering setup.
Posted: Fri Mar 08, 2019 11:07 am
by B.Goode
From the link you cited...
Performance
designed for Raspberry Pi Models B+, 2, 3
60 seconds backup time including a safe shutdown
20 seconds protection against short-term power failure (no shutdown)
Note those times are in seconds, not minutes!
Posted: Fri Mar 08, 2019 11:15 am
by crocket
I know. That might be enough time to shut down. However, I realize that I just want to protect sd card from file corruption caused by rare power outages that happen once per several years.
If SD card can withstand those rare power outages, I won't need a batteryless UPS. I still might want some surge protection from a power strip.
By the way, #250 Universal Power Source (UPS) for only 2$ looks interesting.
Posted: Fri Mar 08, 2019 11:55 am
by Ernst
The SD card is not the problem, it is the unexpected failure of the processor caused by lack of energy.
Posted: Fri Mar 08, 2019 12:09 pm
by crocket
What? Can the CPU on raspberry pi 3B+ die because of power loss? I thought I bought a good piece of equipment.
Posted: Fri Mar 08, 2019 12:14 pm
by fruitoftheloom
What? Can the CPU on raspberry pi 3B+ die because of power loss? I thought I bought a good piece of *.
Without electricity any electrical equipment will not function.
Posted: Fri Mar 08, 2019 12:35 pm
by Ernst
Please read this: https://www.dummies.com/computers/pcs/u ... -supplies/
Posted: Fri Mar 08, 2019 12:48 pm
by jbudd
In your other thread you say that you intend to run the Pi continuously for several years.
Regardless of power outages you probably need to consider the SD card failing due to too many write operations.
One way to prevent this is to set it up with read-only file systems, and if your SD card is read-only, you have nothing to fear from power outages.
Posted: Fri Mar 08, 2019 12:55 pm
by crocket
I think Ernst said a power outage can permanently kill rasberry pi. If it dies permanently, it cannot be powered up again, or it powers up but cannot compute anything properly.
I'm considering following instructions on https://domoticproject.com/extending-li ... pi-sd-card. I might connect a USB hard disk to RPi.
Posted: Fri Mar 08, 2019 1:33 pm
by jbudd
I would have thought that a spinning hard disk is more likely than an SD to suffer damage or corruption from a power cut.
What is the Pi used for? Perhaps read-only filesystems combined with data storage in the cloud would work for you?
by mahjongg
You thought wrong, he probably meant that the CPU would crash, and damage the filing system, not that the PI's hardware will be permanently damaged by a power fail.
Also, please don't swear, I get complaints I have to handle by applying censorship, which I hate to do....
Posted: Fri Mar 08, 2019 1:46 pm
by Ernst
I think Ernst said a power outage can permanently kill rasberry pi. If it dies permanently, it cannot be powered up again, or it powers up but cannot compute anything properly. I'd have to buy a new one.
What this means is that the processor will fail (not die) when power is removed unexpectedly which can have a bigger influence on the contents of the file system on the SD card.
You stated:
The SD can withstand power outages, what do you think happens with SD cards used in cameras when the camera is powered off ? An unexpected loss of power can cause problems in two subsystems, the one subsystem being the SD card processing IO operations and the other subsystem the operating system on the host busy with the other side of the IO operations. The risk that the SD card fails when IO operations are interrupted is quite low, the risk that the file system on the SD gets corrupted is much higher because parts of the data could be written already while other parts are still in RAM when power fails. If this happens to be updates to the administrative areas (like inode table) then anything can go wrong.
Posted: Fri Mar 08, 2019 1:49 pm
by crocket
Man, it must be tough to live in a world where you got to censor *%^^
I got to make backups, then. Is a btrfs snapshot good enough?
It's going to be a gentoo system used for
  • Morning alarm
  • task management with emacs org-mode. I'll ssh into raspberry pi from android and iOS. org-mode files will be synchronized between RPi and my desktop.
  • A git repository for https://www.passwordstore.org/ which will be synchronized between RPi and my desktop. Android and iOS will access it through ssh.
  • wake-on-lan server for my desktop
Although it's gentoo, I will install binary packages built by my gentoo desktop. And, I don't like cloud storage.
A hard disk is a lot more robust against writes. Power outages are rare enough. SD card lifespan is a bigger threat than power outages.
Posted: Fri Mar 08, 2019 2:03 pm
by jbudd
Man, it must be tough to live in a world where you got to censor ....
Wow, you are a charmer arent you?
Posted: Fri Mar 08, 2019 2:21 pm
by rpdom
Actually no. The spinning rust devices have a number of measures to ensure data is correctly written out in case of power failure.
Posted: Fri Mar 08, 2019 2:42 pm
by W. H. Heydt
There are some parameters that aren't spelled out. Such as, how long a power outage do you expect to ride out? What do you consider to be "cheap"?
For protecting a transportable system (that is, one that I can pack up, take with me, and set up when I arrive at my destination) I use: https://www.frys.com/product/8039934?si ... IN_RSLT_PG The cost is a bit more than a Pi, itself, it's not particularly heavy, and it will ride out *most* power outages. Plus--like any UPS--it includes line conditioning and surge protection. At 3.5 lbs., it is reasonably portable.
Posted: Fri Mar 08, 2019 2:49 pm
by crocket
Cheap means it's not more expensive than Pi itself. I wanted up to 10 minutes of operation after power loss so that I could shut it down properly.
However, I decided that it is just cheaper to send a backup of SD card as a btrfs/ZFS snapshot to my desktop and avoid most writes through tmpfs.
