Beorn_Bear
VNC Viewer Display Screen and Minecraft
Sat Jan 19, 2019 7:37 pm
I am currently using VNC viewer to access my raspberry pi 3 B+. However, the VNC Viewer does not display on the full screen of the monitor and the resolution looks low. Does anyone know how to resolve this?
When I run Minecraft, it appears blank through the VNC Viewer. Any suggestions are welcome.
Re: VNC Viewer Display Screen and Minecraft
Sat Jan 19, 2019 7:49 pm
Direct Capture Mode
https://www.raspberrypi.org/documentati ... ccess/vnc/
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
HawaiianPi
Sat Jan 19, 2019 7:51 pm
You can set the desired resolution in the raspi-config utility. If you want to run the VNC session in a window, set the rez a little lover than your monitor. If you want it full screen, set the correct resolution for your screen.
In RealVNC Viewer there are scaling and full-screen controls.
In this example picture, scaling is highlighted in red, and full-screen is left of that.
Be aware that gaming over a remote desktop connection doesn't work well due to lag.
Beorn_Bear
Thu Jan 31, 2019 3:12 am
The mouse and video is slow on my Raspberry Pi 3 B+ while accessing it with VNC Viewer. The mouse lags. Does anyone has suggestions on how to improve it?! Would it be necessary to plug in an ethernet cable into the Raspberry Pi rather than using Wifi??!
DarkPlatinum
Thu Jan 31, 2019 10:39 am
I don't think you will be able to play games over VNC. VNC is basically multiple images being taken and set across the network.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): Https://Html.dynu.net
HawaiianPi
Thu Jan 31, 2019 10:56 am
That's why I said the following in my previous post...
Remote desktop connections are not recommended for gaming, for that very reason. There will always be lag. The Pi is simply not powerful enough to stream games over a remote connection. At least not games that require real-time feedback (turn based games might be okay).
Beorn_Bear
Sat Feb 02, 2019 6:43 am
I am not using the Raspberry Pi 3 B+ for games. I am currently using it as a media server, file backup server and Alexa. When I access it via the VNC Viewer, it is rather slow via wifi. Would an ethernet connection provide a better solution? Is there another work around?
LTolledo
Sat Feb 02, 2019 7:00 am
Can you enlighten us on how you are using VNC in your setup.
What VNC server are you using?
What VNC viewer are you using?
What task are you trying to accomplish while viewing in VNC mode?
Some people be like:
HawaiianPi
Sat Feb 02, 2019 8:49 am
What's your typical CPU utilization with all that running in the background? My guess is you're running low on RAM and swapping, or just getting lag due to an overworked CPU.
WiFi does have more system overhead than Ethernet, but Ethernet is shared with the USB ports, so ... ¯\_(ツ)_/¯ ... (heavy access to anything on USB could impact Ethernet performance). If you're doing a lot of reading or writing to USB storage then WiFi may be best, but there are so many things that affect WiFi it's hard to predict. Try it both ways and see which works best for you.
