Faruk
pigpio error: "no permission to update GPIO"
Sat Jan 12, 2019 1:57 pm
Hello
I work on script so I want control to backlight of LCD screen with PWM(software). It is worked earlier but it does not work now. I commented out bakclight divide and worked on the other modules on software. Now I want use but I took this error. I researched on net but I could not fix this. How can I fix this error? My pwm code divide this:
improt RPi.GPIO as gpio
import pigpio
pi=pigpio.pi()
print (pi.connected)    #Test for pigs t
gpio.setmode(gpio.BCM)
gpio.setwarnings(False)
gpio.setup(33, gpio.IN)  #Pin of DW button
gpio.setup(30, gpio.OUT) #Pin of backlight
gpio.setup(39, gpio.OUT) #Pin of lcd on/off function
#-Backlight and LCD open-#
def screenopen():
    global pi
    global screenflg
    screenflg=False
    print "screen open start"
    try:
        gpio.output(39,1)
        pi.set_PWM_frequency(30,100)
        for i in range(0,155,30):
            pi.set_PWM_dutycycle(30,i)
            time.sleep(0.01)
        print "screen open end"
    except:
        import traceback
        traceback.print_exc()
        prgloop()
Regards
Re: pigpio error: "no permission to update GPIO"
Sat Jan 12, 2019 2:39 pm
What error? You have not shown it.
Try running with sudo like so:
$ sudo python myProg.py
Faruk
Sat Jan 12, 2019 2:52 pm
Error is:"no permission to update GPIO". Return this error. I will try. If I would not work it. I think use new image. Because I try for do this different way but my Rpi reboot itself.
Sat Jan 12, 2019 3:15 pm
You appear to be mixing some pigpio code (which you've imported) with lots RPi.gpio code (which you haven't imported).
I'd recommend you pick one or the other.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Faruk
Mon Jan 14, 2019 5:18 am
I edited my code I forgot first line. Sorry. Also I tried use just GPIO(not pigpio) so my rpi reboot itself when run program. I could not understand why? I researched now.
Faruk
Mon Jan 14, 2019 9:23 am
All of error this:
  File "/home/pi/Petra/PGUI.py", line 166, in updateGUI
    screenclose()
  File "/home/pi/Petra/PGUI.py", line 95, in screenclose
    pi.set_PWM_frequency(30,255)
  File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 1586, in set_PWM_frequency
    _pigpio_command(self.sl, _PI_CMD_PFS, user_gpio, frequency))
  File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 975, in _u2i
    raise error(error_text(v))
error: 'no permission to update GPIO'
I could not find any solution.
