Kodi PVR
Posted: Fri Dec 28, 2018 4:35 am
by thadaddyy
Hey guys, what is the best hardware/software combo to record live TV in Kodi? I'm in Canada and basically looking for PVR type function.
Re: Kodi PVR
Posted: Fri Dec 28, 2018 3:38 pm
by fruitoftheloom
How do you receive TV ?
Aerial, Satellite, Internet ?
Re: Kodi PVR
Posted: Fri Dec 28, 2018 4:18 pm
by mikronauts
Hdhomerun + kodi should do it.
Re: Kodi PVR
Posted: Fri Dec 28, 2018 6:35 pm
by thadaddyy
I'm getting TV via the internet. For HDhomerun is it best to use the hdhomerun pvr add on in Kodi?
Re: Kodi PVR
Posted: Fri Dec 28, 2018 6:53 pm
by mikronauts
You wrote tv in canada... I assumed you meant over the air atsc.
No idea on how to record streams.
Re: Kodi PVR
Posted: Fri Dec 28, 2018 7:00 pm
by fruitoftheloom
https://kodi.wiki/view/PVR/Backend/IPTV
Re: Kodi PVR
Posted: Fri Dec 28, 2018 7:11 pm
by thadaddyy
Thanks this helps a lot, my only question is to record IPTV can you use the back end software OR hardware or do you need both.
Re: Kodi PVR
Posted: Fri Dec 28, 2018 8:56 pm
by default_user8
You will need a tuner(HDHomerun) pointed at at backend, typically something like TVheadend. If you used the Libreelec image for kodi tvheadend is already installed you just need to choose which one you want to use and enable it.
Re: Kodi PVR
Posted: Fri Dec 28, 2018 9:41 pm
by thadaddyy
Ok thanks that makes sense, yes I'm using Libreelec and I tvheadend is already there. Looks like I'll be in the market for a tuner now!
Re: Kodi PVR
Posted: Fri Dec 28, 2018 10:38 pm
by fruitoftheloom
https://kodi.wiki/view/Add-on:IPTV_Simple_Client
Should be all you need to watch IPTV ?? have you tried ??
Re: Kodi PVR
Posted: Sat Dec 29, 2018 12:32 am
by thadaddyy
Oh yeah I've used IPTV Simple Client, it works great for watching IPTV but my issue was recording something from the guide (without a tuner).
Re: Kodi PVR
Posted: Sat Dec 29, 2018 5:13 am
by fruitoftheloom
YMMV
https://forum.kodi.tv/showthread.php?tid=326896
