4phoenix
Etcher for Raspberry Pi, no more need a PC for flash!
Tue Dec 11, 2018 4:39 pm
Now you can install etcher on Pi :
https://www.facebook.com/groups/1734745926585704/
Search etcher and you will see a video and the link for download, work fine. Salvador Liébana port etcher to Raspberry Pi no more PC needed!
Salvador Liébana video etcher:
https://youtu.be/tKbH6CEgtU0
fbe
Re: Etcher for Raspberry Pi, no more need a PC for flash!
Tue Dec 11, 2018 9:26 pm
A PC was never needed to flash a Raspian image if you have a running Raspbian and a card reader or a USB MSD and one of the RPi models that can boot from it. But PC often have USB3 ports, that can save a lot of time when copying gigabytes.
If you are comfortable with USB2 speed you could use lsblk to identify your target device, if needed unmount it and then run something like:
unzip -p 2018-11-13-raspbian-stretch.zip 2018-11-13-raspbian-stretch.img | sudo dd of=/dev/sd{x}
instead (replace sd{x} by your device, e.g. sda).
mikerr
Tue Dec 11, 2018 10:24 pm
You can also flash an SD card direct on your android phone :
viewtopic.php?f=63&t=170856
W. H. Heydt
Tue Dec 11, 2018 11:02 pm
:-) Another point in favor of having USB 3 on a future Pi...
DavidS
Tue Dec 11, 2018 11:39 pm
I still think that just copying the file to the device is a better and easier way in Linux (on the RPi). I usually use dd for this purpose.
I just wish there were as simple of a way to do it from RISC OS (though I will settle with a good method from AROS once we have a usable native stand alone version of AROS).
