MuntyScruntfundle
Very small relay?
Sun Dec 09, 2018 5:24 pm
Hi there.
I need to control a bunch of fans from a pi, too many to control from the 5v pin. So I thought I'd use either a 5v or 3v pin to trip a relay which would open a 5v or 12v (fans undecided at present) line to power them.
The relays would have to be pretty small and surface mount for proto board.
Could a kind person please recommend a couple of options?
Many thanks.
Brandon92
Re: Very small relay?
Sun Dec 09, 2018 5:50 pm
Is there a specific reason for you not to use a (NPN) transistor or a (n channel) MOSFET? Those components are smaller that a relais. And if you need the isolation layer. You could also use a optocoupler.
You could also use a PMW (computer) fan. Then you can control the fan speed. And if it need to be "on" or off.
edit:
To give you some ideas of a small relay. You can't connect those relais directly to the GPIO, they will destroy that pin. Because the relais coil need to much current:
