jonnyb
Kodi Edition Raspberry Pi Case (v2) VS FLIRC Raspberry Pi Case
Sun Dec 09, 2018 1:54 pm
Kodi Edition Raspberry Pi Case (v2) VS] FLIRC Raspberry Pi Case
Does anyone have any idea what the difference is between these two cases? The Kodi one is later but I can't see what improvements there are....
HawaiianPi
Re: Kodi Edition Raspberry Pi Case (v2) VS FLIRC Raspberry Pi Case
Sun Dec 09, 2018 5:42 pm
The Kodi Edition was the first generation case that was designed for the Pi 2B, and is not really compatible with the Pi 3B models (you can't see the LEDs, and the micro SD card is difficult to remove). I'm not aware of a V2 Kodi case (if there's a newer model can you post a link).
The Flirc generation 2 case is designed for the newer Pi 3B and 3B+ models. It allows viewing the LED indicators, and has a slot for access to the micro SD card. I use the Gen2 case for most of my Pi3B(+) computers. It keeps them running (and looking) very cool.
jonnyb
Sun Dec 09, 2018 8:25 pm
Thanks for the info ...
This is the new one below ...
https://thepihut.com/products/kodi-edit ... ry-pi-case
I'm going to buy this one or the FLIRC but trying to work out if one has any benifits over the other ..
HawaiianPi
Mon Dec 10, 2018 12:27 am
That does look like the Flirc Gen2 case.
However, they don't mention 3B+ compatibility, so I'm guessing it only includes the thicker thermal pad for the older 3B model. The Flirc Gen2 case also includes a thinner thermal pad for the newer 3B+ model.
jonnyb
Mon Dec 10, 2018 10:18 am
It's definately compatitable with the 3B+. There's a compability note on the ist page ....half way up the page on the right. No idea what the differences are between the two though....
HawaiianPi
Mon Dec 10, 2018 11:19 am
Other than the little green box by the price there's no mention of the 3B+ and only a single thermal pad is indicated. If that's just an oversight in the description, then it's exactly the same case as the Flirc Gen2, except it's black and the top snap on plastic decorative panel has the Kodi logo. If you think that's worth an extra £3 then get the Kodi case.
The standard Fllrc Gen2 case is a matte silver/aluminum color with a flat black top panel and includes 2 thermal pads (picture in my previous post above is what I received when I ordered a new 3B+ and Flirc Gen2 case).
That plastic top panel easily snaps off and on with the case open, so it could be decorated in a variety of ways.
jonnyb
Mon Dec 10, 2018 1:38 pm
I've just found out that boths case are the same but the Kodi one is branded.... and that's it ... nothing else...
jonnyb
Mon Dec 10, 2018 1:55 pm
I went for the FLIRC (2) ... Look good .. Thanks...
bensimmo
Mon Dec 10, 2018 3:24 pm
Just to add a bit more info on the Kodi case.
https://kodi.tv/article/kodi-edition-ra ... rce-be-you
jonnyb
Tue Dec 11, 2018 9:26 am
Cheeky of them really. They make it sound like they've improve dit but one of the authorised sellers tells me it just has the kodi branding... that's it... Maybe there are wrong but they seemed certain.
bensimmo
Tue Dec 11, 2018 10:04 am
Maybe they worked with the person who designs the FLIRC case and brought that design out.
Though it is an improvement over the original KODI case.
I would guess/assume/anyone know the extra money over the FLIRCv2 is the money for charity ?
HawaiianPi
Wed Dec 12, 2018 12:34 am
Cheeky of them really. They make it sound like they've improved it but one of the authorised sellers tells me it just has the kodi branding... that's it... Maybe there are wrong but they seemed certain.
The Kodi branding, along with the new aesthetics could be considered an improvement, depending on your taste.
While the description on the Kodi product page wreaks of marketing-speak, nowhere did they claim improved performance over the Gen2 Flirc. They simply state the design improvements associated with the Gen2 Flirc, and focus on the new aesthetics. Personally, I'm not a fan of that Kodi logo top plate, but the black with polished edge does look nice.
jonnyb
Thu Dec 13, 2018 9:58 pm
I agree ... and what if I change from Kodi to something else .... ?!?!?
bensimmo
Fri Dec 14, 2018 8:45 am
The case stops working.
HawaiianPi
Fri Dec 14, 2018 10:13 pm
@jonnyb,
The plastic top plate is easily removed when the case is open (4 push tabs). You could then decorate it as you please with paint, vinyl or stickers (or if you have access to a 3D printer, a new plate could be made). You can see 2 of the lock tabs in my picture of the open case above.
