shishirbitm
Mic not capturing audio with Plantronics BT300M
Sat Dec 08, 2018 7:11 am
Hi, I am not able to record on raspberry pi 3b+ with following device. Although i can find my device configured below. Kindly help.
Playback works but record doesn’t work. Also I am trying to record programatically through java audio, that also doesn’t work. Recording file has constant slight noise and no recording sound.
Playback works fine but recording doesn’t:
Playback command: Works well
arecord –format=S16_LE –rate=16000 | aplay –format=S16_LE –rate=16000
Recording doesn’t work:
arecord –format=S16_LE –rate=16000 test.wav
Below are the device listing:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: BT300M [Plantronics BT300M], device 0: USB Audio [USB Audio]
Subdevices: 1/1
pi@raspberrypi:~ $ arecord -l
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
lsusb
Bus 001 Device 004: ID 047f:0416 Plantronics, Inc.
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
alsamixer is also fine, I can see both capture and playback is correctly configured.
