abest12
USING Raspberry PI3 with third party Touch screen (15")
Fri Dec 07, 2018 10:36 pm
Has anyone found a @ 13"- 15" TOUCH SCREEN Monitor that can work with the PI3 I purchased a Monitor but Drivers have to be loaded for the touch screen to work , i'm not sure how to do this into the PI3.. Any help on how this is done or a monitor recommendations would be very helpful Thanks In advance
Re: USING Raspberry PI3 with third party Touch screen (15")
Sat Dec 08, 2018 7:46 am
Is the screen HDMi ?
Is the touch screen controlled via USB connection ?
If the touch is via USB then plug it in and post back output of:
lsusb -v
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
abest12
Sat Dec 08, 2018 2:04 pm
Thanks for your reply the Monitor has HDMI/VGA and has a USB Input . When plugging into HDMI I can see everything perfectly on Monitor just don't have the Touch Screen capability , Manufacture manual comes with instructions to download and install driver from there link . I have the Driver zip file downloaded onto my PC . Do you know to install this driver onto the Pi3
this is the monitor
https://neewer.com/product/10090894/
Sat Dec 08, 2018 2:55 pm
this is the monitor
The link you provided does not state Linux ARMHF !
Is the Touch control via USB ??
adieu
drgeoff
Sat Dec 08, 2018 4:14 pm
The touch part of touch screens never works via the HDMI cable. In this case the touch function needs the USB cable connected.
The driver available for download is for Windows PCs with Intel/AMD/etc processors. Don't even try to install it on a RPi.
You were asked to plug in to USB and give the result of
lsusb -v
but you did not.
abest12
Sat Dec 08, 2018 6:02 pm
I did Plug in USB , but no way to change the Input selection only options are VGA/PC/HDMI I think the USB is only for uploading updating Monitor. If you know any other way please let me know or maybe a 13-15" monitor that would work Thanks for you help
Sat Dec 08, 2018 6:07 pm
Usually the Touch is via USB connection ??
adieu
PhatFil
Sat Dec 08, 2018 8:07 pm
so if you plug in the monitor/usb connection and run the lsusb (list usb) command above
lsusb -v
you should get some information about what the Pi Thinks is currently plugged in.. and from there.....
abest12
Sat Dec 08, 2018 8:48 pm
The only way I can get any display is with HDMI so I can get to command screen is with it connected and then I also plug in USB from PI to Monitor typing that command returns command not found I tried 1susb -v and also tried sudo 1susb -v same not found returns
Sat Dec 08, 2018 8:51 pm
It is a lower case L ie between k and m !
adieu
drgeoff
Sat Dec 08, 2018 8:59 pm
You seem to have difficulty comprehending that the HDMI port on the monitor is a video input from the RPi and the USB port is for sending the mouse-like signals from the touch screen to the RPi. The HDMI and USB ports are independent and neither can do what the other one does.
abest12
Sat Dec 08, 2018 9:28 pm
Thanks for your help I'm Trying to follow along , so what do you suggest I do to get the TOUCH Screen monitor to work with touch commands
drgeoff
Sat Dec 08, 2018 10:52 pm
Give us the answer to
lsusb -v
Sat Dec 08, 2018 11:00 pm
lsusb -v
I have given up :?
adieu
Andyroo
Sat Dec 08, 2018 11:30 pm
Has anyone found a @ 13"- 15" TOUCH SCREEN Monitor that can work with the PI3 ...
If you cannot run the commands you may do better with:
14 inch KIT from here https://www.youtube.com/watch?v=eSKmG1VFA4w but you will need a housing
Need Pi spray - these things are breeding in my house...
PhatFil
Sun Dec 09, 2018 1:50 am
usb overlay touchscreens you can sit atop any other screen are easily available.
https://www.amazon.co.uk/GreenTouch-tou ... en+overlay
for example..
abest12
Sun Dec 09, 2018 1:12 pm
Thanks for all your Help , I'm just sticking with a 10" Raspberry Touch screen and calling it a day
