Fan174
sending alerts to many one or more people
Wed Dec 05, 2018 9:47 am
I am using Raspberry Pi to monitor events and want to send SMS to one or more people on mobile
I have created following GUI to enter mobile number
from tkinter import *
def callback():
    print ("You clicked the button!")
top = Tk()
L1 = Label(top, text="Mobile")
L1.grid(row=4, column=0)
E1 = Entry(top)
E1.grid(row=4, column=1)
MyButton1 = Button(text="Submit", width=0, command=callback)
MyButton1.grid(row=4, column=3)
mainloop()
Python API code to send text sms link http://api.textlocal.in/docs/sendsms
#!/usr/bin/env python
import urllib.request
import urllib.parse
def sendSMS(apikey, numbers, sender, message):
    data =  urllib.parse.urlencode({'apikey': apikey, 'numbers': numbers,
        'message' : message, 'sender': sender})
    data = data.encode('utf-8')
    request = urllib.request.Request("https://api.textlocal.in/send/?")
    f = urllib.request.urlopen(request, data)
    fr = f.read()
    return(fr)
resp =  sendSMS('apikey', '918123456789',
    'Jims Autos', 'This is your message')
print (resp)
How to integrate python code with GUI
scotty101
Re: sending alerts to many one or more people
Wed Dec 05, 2018 9:55 am
Its not difficult, just call the sendSMS function from your callback function.
You also need to get the value of the text box and pass that to the sendSMS function.
Something similar to this should probably work
#https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=228355
import urllib.parse
    fr = f.read()
    return(fr)
def callback():
    number = E1.get()
    resp =  sendSMS('apikey', number,'Jims Autos', 'This is your message')
    print ("You tried to send a message\n", resp)
top = Tk()
E1 = Entry(top)
mainloop()
(Code untested since I don't have an API key)
Fan174
Wed Dec 05, 2018 10:44 am
Thanks scotty101, I am outside from home. This is the untested code
if the sensor triggered send sms to many people
import RPi.GPIO as GPIO
import urllib.parse
"""Setup the GPIO Pins"""
GPIO.setmode(GPIO.BCM)
GPIO.setup(21,GPIO.IN) # button from pin 40 to gnd
SensorHigh = 0
TOTAL = 0
    fr = f.read()
    return(fr)
def callback():
    number = E1.get()
top = Tk()
E1 = Entry(top)
def FAULTbuttonPressed(channel):
    global SensorHigh , TOTAL
    SensorHigh  = SensorHigh  + 1
    Label(text= SensorHigh , relief=RIDGE,width=10).grid(row=1,column=1)
    TOTAL = TOTAL + 1
    Label(text=TOTAL, relief=RIDGE,width=10 ).grid(row=2,column=1)
GPIO.add_event_detect(21, GPIO.FALLING, callback=FAULTbuttonPressed, bouncetime=250)
Label(text='Sensor Activate',  relief=RIDGE,width=10 , height= 5 ).grid(row=1,column=0)
Label(text=SensorHigh , relief=RIDGE, width=10 , height= 5 ).grid(row=1,column=1)
Label(text='TOTAL', relief=RIDGE,width=10, height= 5 ).grid(row=2,column=0)
Label(text=TOTAL, relief=RIDGE, width=10, height= 5).grid(row=2,column=1)
mainloop()
If you see mistake in code please let me know
Fan174
Thu Dec 06, 2018 5:48 am
I tried your code but getting error
may be I am making mistake somewhere so I am posting code with error
import urllib.parse
    data =  urllib.parse.urlencode({'apikey': ***********, 'numbers': number,
        'message' : message, 'sender': VJRTC})
    fr = f.read()
    return(fr)
def callback():
    number = E1.get()
top = Tk()
E1 = Entry(top)
mainloop()
When I submit number it show following message
error message
Exception in Tkinter callback
File "/usr/lib/python3.5/tkinter/__init__.py", line 1562, in __call__
return self.func(*args)
File "test10.py", line 18, in callback
File "test10.py", line 8, in sendSMS
data = urllib.parse.urlencode({'apikey': , 'numbers': number,
NameError: name '***********' is not defined
scotty101
Thu Dec 06, 2018 9:37 am
Change
to
def sendSMS(apikey, number, sender, message):
scotty101
Thu Dec 06, 2018 9:42 am
If that is exactly the error you are getting, its because ************** isn't valid. If *********** is supposed to be your API key try putting it inside quotes like '*****************' e.g. '123456789'
Fan174
Thu Dec 06, 2018 3:48 pm
I know I tried with original API key I think I am mistaking somewhere
Can you guess what may be wrong in code
import urllib.parse
    data =  urllib.parse.urlencode({'gjhfyiyiyiy5999jghjgugugyfyf': apikey, 'numbers': numbers,
    fr = f.read()
    return(fr)
def callback():
    number = E1.get()
    resp =  sendSMS('gjhfyiyiyiy5999jghjgugugyfyf', number,'Jims Autos', 'This is your message')
top = Tk()
E1 = Entry(top)
mainloop()
This code is untested also This is not oruginal APIKEY
scotty101
Thu Dec 06, 2018 4:48 pm
Does this work? I've tested as much as i can without actually making the urllib request.
import urllib.parse
    data =  urllib.parse.urlencode({'apikey': apikey, 'numbers': number,
    fr = f.read()
    return(fr)
def callback():
    number = E1.get()
top = Tk()
E1 = Entry(top)
mainloop()
Fan174
Thu Dec 06, 2018 5:20 pm
I don't have pi in hand I will test it at home
you did a lot help, please take look at this code and please tell me If I am making something wrong
import urllib.parse
SensorHigh = 0
TOTAL = 0
    fr = f.read()
    return(fr)
def callback():
    number = E1.get()
top = Tk()
E1 = Entry(top)
    TOTAL = TOTAL + 1
mainloop()
untested code, thinking final code should be look like above code
scotty101
Thu Dec 06, 2018 5:31 pm
I'm not a fan of what you are doing here
    TOTAL = TOTAL + 1
You'll create new labels each time there is a falling edge on GPIO 21. I'd suggest creating the labels when you create the "Sensor Activate" and "TOTAL" caption labels and the function that is called when GPIO 21 callback is triggered should just update the count and change the text to display the newly incremented number.
I'll create an example and update this post.
scotty101
Thu Dec 06, 2018 5:36 pm
Ok. I'd still rewrite it to improve the code but this does at least show how it might work. I've added an extra button and function to simulate the GPIO falling edge but you can comment these out.
Code has been modified to update the labels that contain the SensorHigh and TOTAL counts rather than create a new label each time.
#import RPi.GPIO as GPIO
import urllib.parse
SensorHigh = 0
TOTAL = 0
    fr = f.read()
    return(fr)
def callback():
    number = E1.get()
top = Tk()
E1 = Entry(top)
    TOTAL = TOTAL + 1
    lblSensorHigh['text'] = SensorHigh
    lblTotal['text'] = TOTAL
#Comment this out for your version
def trigger():
    FAULTbuttonPressed(21)
Label(top, text='Sensor Activate',  relief=RIDGE,width=10 , height= 5 ).grid(row=1,column=0)
lblSensorHigh = Label(top, text= SensorHigh , relief=RIDGE,width=10)
lblSensorHigh.grid(row=1,column=1)
Label(top, text='TOTAL', relief=RIDGE,width=10, height= 5 ).grid(row=2,column=0)
lblTotal = Label(top, text=TOTAL, relief=RIDGE,width=10 )
lblTotal.grid(row=2,column=1)
Button(text="GPIO Dummy",command=trigger).grid(row=5,column=0)
top.mainloop()
(Not sure why would have two counts SensorHigh and TOTAL given that they are both updated at the same time...)
Fan174
Sat Dec 08, 2018 9:47 am
I testd,It gives this error
{"errors":[{"code":80,"message":"invalid template"}],"status":"failure"}
scotty101
Sun Dec 09, 2018 10:01 pm
Can't help with that. Looks like something wrong with the call to the website to send the text.
As I don't have an API key, I can't help you.
Fan174
Mon Dec 10, 2018 10:42 am
.(Not sure why would have two counts SensorHigh and TOTAL given that they are both updated at the same time...)
When I run following program I am getting message on mobile
import urllib.parse
    data =  urllib.parse.urlencode({'apikey': apikey, 'numbers': numbers, 'message' : message, 'sender': sender})
    fr = f.read()
    return(fr)
resp =  sendSMS('gjhfyiyiyiy5999jghjgugugyfyf', '919923456789', 'Dejn', 'This is your message')
print (resp)
Now I don't want to create a GUI to submit mobile number.
Now what I want if faulty product detect on conveyer belt , send message to person and count how many faulty product detected
one sensor is connected to raspberry pi (pin 21) . This sensor detects faulty product
create one GUI to show faulty lable detect
create another GUI to show how many faulty product detected
import urllib.parse
    fr = f.read()
    return(fr)
print (resp)
SensorHigh = 0
TOTAL = 0
top = Tk()
    TOTAL = TOTAL + 1
top.mainloop()
problem is that intially i am getting message but when sensor detects faulty product I am not getting the message
I have doubt in program because there is no If condition to check sensor Please help me in program
GPIO.setup(18, GPIO.IN,pull_up_down=GPIO.PUD_UP)
while True:
    inputValue = GPIO.input(21)
    if (inputValue == True):
        print("Product detected ")
scotty101
Mon Dec 10, 2018 11:02 am
If you want something to happen (send an SMS) based on the GPIO pin, you'd need to add code to the "FAULTbuttonPressed" function which is called by the GPIO callback. You don't need an "if" when you are using the "add_event_detect" method of the GPIO library.
At the moment your code just sends the SMS every time you run the code and not based on the GPIO pin.
Copy and Pasting code from the internet is one way to learn but it seems like you don't understand what the code does. Perhaps you would benefit from taking an online python tutorial course?
Fan174
Mon Dec 10, 2018 11:33 am
I am not good in python but trying to learn. I never worked with GUI and SMS service that's why I am confused
I am thinking like this
import urllib.parse
    fr = f.read()
    return(fr)
def callback():
print (resp)
SensorHigh = 0
TOTAL = 0
top = Tk()
    TOTAL = TOTAL + 1
detect = callback()
top.mainloop()
code untested
scotty101
Mon Dec 10, 2018 12:01 pm
Why not just test your code and find your own bugs?
Try something like this instead (Most of the code removed so you actually have to understand what I've done)
    fr = f.read()
    return(fr)
    TOTAL = TOTAL + 1
    print (resp)
top.mainloop()
Note: In the future you may wish to add some code so messages can only be sent every 5 minutes (for example). Unless you want a huge bill for sending too many messages.
