Flyback Diodes - Solenoid Valves
Posted: Tue Nov 27, 2018 11:28 am
by TomFisher
Hi guys,
My first project with the Raspberry Pi involves switching 24v solenoid valves on and off using a relay. Am I correct in thinking I need to use a diode across the solenoid valve? If so - how would I go about speccing this diode? A 1N4001 seems to be commonly used, would this be suitable?
The valves are these: https://uk.rs-online.com/web/p/pneumati ... s/8929993/
and the relay I propose to use is: https://www.amazon.co.uk/SunFounder-Cha ... B00E0NTPP4
Thanks a lot!
Tom
Re: Flyback Diodes - Solenoid Valves
Posted: Tue Nov 27, 2018 11:57 am
by drgeoff
Yes and yes.
(Make sure you get the polarity correct. Band on diode to positive on solenoid,)
Posted: Tue Nov 27, 2018 12:13 pm
by 6by9
If using a relay then I'd say there was little need for the flyback diode. The potential on one contact of the relay goes up, but that's not going to cause any grief (unless it could get high enough to arc).
If using a transistor then you certainly do need them to avoid blowing up the transistor. The coil side of your relay board already has them fitted as it is relevant there too.
The 1N400x series are certainly the most common diodes used for this sort of thing.
Posted: Tue Nov 27, 2018 1:31 pm
by Mortimer
Surely there will be an arc between the relay contacts every time the contacts are opened (and the circuit is powered of course). Yes this won't destroy the relay as quickly as the back EMF could take out a transistor, but diodes being as cheap as they are why wouldn't you? It should prolong the life of the relay contacts, possibly indefinitely.
Posted: Tue Nov 27, 2018 1:57 pm
by 6by9
There's the potential for a very small arc, but I wouldn't expect it to reduce the lifespan significantly.
In this case there is no harm in doing so, but no absolute need. Just don't later switch to the AC version of the solenoid unless you like exploding diodes!
Posted: Tue Nov 27, 2018 2:45 pm
by davidcoton
The standard wisdom is that back EMF arcing can reduce relay contact life significantly. Back EMF supression diodes should be included as a matter of routine, since they will also reduce EMI if properly fitted directly at the solenoid coil. It also protects against a later revision replacing the relay with a transistor...
Posted: Tue Nov 27, 2018 3:12 pm
by jdb
I'm assuming that this is a low-voltage DC solenoid (24Vdc).
Two points of note from someone who used to fix systems using electromechanical components:
Adding a snubber across the solenoid coil is the best method of protecting the control relay contacts. A snubber can either be a diode, RC filter or other more complex arrangement.
Adding a simple anti-parallel diode across the solenoid coil suppresses the additional back EMF to just +1V above the supply voltage, but will considerably increase the "opening" time of whatever it's mechanically connected to. When the relay contact opens, current in the solenoid coil decays as L/R, with the mechanical force proportional to the decaying current. The forward-biased diode is a "small" resistance, so the decay time is large. This causes the solenoid to release far more slowly than if it was simply open-circuited.
An RC filter can be used, but this requires tuning specific to the coil.
A cheap but best-fit solution is to use a diode-zener clamp - add a 10-20V zener diode in series opposition to the standard diode - this increases the effective resistance (and thus speed) of the snubber while clamping the voltage that the relay contacts will be exposed to.
https://electronics.stackexchange.com/q ... r-analysis
Posted: Tue Nov 27, 2018 3:27 pm
by joan
The linked relay module has all the protection you need. I do not understand why others are saying you need more.
Posted: Tue Nov 27, 2018 3:48 pm
by drgeoff
:shock:
The relay module has protection for whatever onboard device is driving the relay coil. It does NOT have any protection for the relay contacts.
Posted: Tue Nov 27, 2018 5:26 pm
by davidcoton
Thank you, I've learnt something!
