JamesPi123
lb.raspberrypi.org
Mon Nov 26, 2018 6:22 am
What is lb.raspberrypi.org? I have noticed it showing up for raspberrypi.org in google.
example: I go to google and type: rpi 10 amp
The top result is https://lb.raspberrypi.org/forums/viewtopic.php?t=16295
What is this website and why does this exist?
epoch1970
Re: lb.raspberrypi.org
Mon Nov 26, 2018 10:13 am
Lb=load balancer
Lb forwards to available instances to actually do the work.
JamesPi123
Tue Nov 27, 2018 10:12 am
