Zizico2
Solved: Pull the plug
Sun Nov 18, 2018 11:20 pm
Hi mates! According to the oficial FAQ O shouldn't just unplug the pi from the wall as it might corrupt the SD Card. If I use any other media to boot the OS (SSD,hdd,usb thumb drive), will I get the same problem? If so is there any workaround? I've thought of using a button to shutdown the pi (through a python/shell script) but as I'll not be the one operating it I don't really like that solution. Thanks in advance!
Andyroo
Re: Pull the plug
Mon Nov 19, 2018 12:56 am
No matter what the media is there is a chance that the disk will corrupt as Linux can cache data before its flushed to disk.
There are many ways to use a button to both shutdown and power on the Pi but they require the machine to be operational.
Best bet is to use the shutdown command after programs are closed.
HawaiianPi
Re: Pull the plug
Mon Nov 19, 2018 2:35 am
The above statements are true for Raspbian, but there are other options (like Tiny Core Linux, which is an OS that runs entirely from RAM). Persistence is the main issue. If you don't need to save data between boots, then something like Tiny Core could allow powering off at any time.
If you DO need to save data, then it gets more complicated, because you would have to ensure that important data is written out before the system is powered down. The safest way to do that is with a proper software shutdown, then wait for the ten flashes of the green activity LED, and then disconnect the power. You could disable write caching to minimize the risk of data corruption in the event of a sudden power loss, but that's not 100% guaranteed to work. Data could be saved to the cloud or a server (depending on what you need to save).
A button on GPIO with a script or software that performs a proper shutdown could be combined with another button on the run header to start the system back up, without actually disconnecting the power (it only draws a tiny amount of power when shutdown).
Not really sure what you need because you didn't explain what you are trying to accomplish.
DavidS
Re: Pull the plug
Mon Nov 19, 2018 3:03 am
While any reasonable OS is going to cache data, some options are less likely to cause FS curruption depending on application.
RISC OS is not as likely to cause curruption from a hard power down like that. Then there are even other non-Linux options, some of which are not as lazy about flushing out cache, and thus reduce the probability of curruption.
Put simply it is the same reason that, before you umount a mass storage device, you manually flush the cache with the sync command in Linux and most other Unix like systems, or by using the Dismount command in RISC OS.
It is just safe practice.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
W. H. Heydt
Re: Pull the plug
Mon Nov 19, 2018 3:24 am
The simplest way to set up a "pushbutton to shut down" is to add "dtoverlay=gpio-shutdown" to /boot/config.txt and rig a NO momentary contact switch across pins 5 and 6. Push once to shut down the system. Push again to reboot it.
Zizico2
Re: Pull the plug
Mon Nov 19, 2018 5:00 am
How would I go about running tinyCore entirely from RAM? While saving data would be the optimal cenario I can live without it. And an idea I just had was to include a battery that charges while the whole thing is plugged in. And when the device would get unplugged It would trigger a gpio pin and run the shutdown command, with the battery powering the Pi.
Do you think it is doable?
EDIT: Ignore the first question xd.
Re: Pull the plug
Mon Nov 19, 2018 5:11 am
Tiny Core Linux:
http://forum.tinycorelinux.net/index.ph ... ,57.0.html
Retired disgracefully.....
W. H. Heydt
Re: Pull the plug
Mon Nov 19, 2018 5:40 am
Doable? Yes. Easy? Not so much. The best way to handle that scenario is to get a UPS designed for the Pi. The big problem here is that most people think "Batteries...Li Ion/LiPo." The problem with that is that very few commercial battery packs permit charging while in use (charging Lithium batteries is tricky and if done wrong makes for truly spectacular results...that you wouldn't like). The attached UPS I'm most familiar with are the MoPower units. They can use most types of batteries other than Lithium. They will permit what you want to do, though.
Zizico2
Re: Pull the plug
Mon Nov 19, 2018 6:17 am
Thanks! I'll look into it.
Zizico2
Re: Pull the plug
Mon Nov 19, 2018 6:24 am
Wait... Could I not do this with a good ol' battery bank I have laying around?
morticiaskeeper
Re: Pull the plug
Mon Nov 19, 2018 6:48 pm
I have been running a HUD speedo on a Pi Zero for almost two years.
Approximately twenty times a day, five days a week, it has had the power supply cut when I switch off the ignition. Never had a problem.
Over the last month, I've also had a SQL database recording up to four thousand records per day. I put a shutdown button, but have forgotten it a few times, still without problems.
hippy
Re: Pull the plug
Mon Nov 19, 2018 8:34 pm
Some people can step into roads without ever looking and never get run over. Some people smoke 40 cigarettes a day and never get cancer or COPD. Some people regale others with entertaining tales of how often they have 'electrocuted' themselves, have been hit by lightning, have been involved in car crashes, or falls from high up.
Not everyone is so lucky. And I would never bank on an outcome being the same as for anyone who has been. Especially when the evidence is that most people's experience diverges from that.
"Never had a problem" is not "won't ever have a problem". Not so far, no.
W. H. Heydt
Re: Pull the plug
Mon Nov 19, 2018 9:28 pm
Ah...so you've heard of James Nicoll.
W. H. Heydt
Re: Pull the plug
What kind of "good ol' battery bank"?
Re: Pull the plug
Mon Nov 19, 2018 10:52 pm
I had a friend like that. He had all sorts of crazy bad things happen to him, but kept on going. We buried him earlier this year, along with his SD cards. (actually, that second part isn't true. The cards were reused).
ejolson
Re: Pull the plug
Tue Nov 20, 2018 1:14 am
Even without cancer a significant amount of smoking will result in physiological changes that, even if unnoticed, are measurable and not insignificant. With an SD card, there are so many files that are unused on a typical Raspbian system that significant data corruption could go unnoticed for a long time: The system continues to boot and appears to function normally. On the other hand, files not in use are also less likely to be corrupted by a sudden power loss.
What brand of SD card are you using that appears resilient to data corruption when pulling the plug?
morticiaskeeper
Re: Pull the plug
Tue Nov 20, 2018 8:04 pm
All my cards are Sandisk. I don't buy them online, I just go down to Argos.
My HUD speedo was designed for a car with van with permanent power, but the later vans cut the power, so I haven't had much choice. The SQL unit has a shutdown button, but I have forgotten a few times.
I do try to shut down my pi's properly, but it doesn't worry me too much to pull the plug. I know of a commercial pi based system that is always has the plug pulled, but the card is very tightly controlled in the app.
Zizico2
Re: Pull the plug
Tue Nov 20, 2018 10:48 pm
One with power passthrough and without a power button xd
